It was the fat version. It was not an easy job, but since I had spent all my money on a soldering iron with 0.15mm tip and the mod chip I just had to try.
The mod worked with the ps2 in pieces, but every time I put all the covers on it wouldn't boot. I resoldered a lot of wires and it still wouldn't work with covers on. In the end I made a short circuit that killed the ps2.
51. I do embedded circuit design hardware & software & pcb layout for a living and have access to really good equipment and microscopes & test equipment. As I get older the parts get smaller, so the microscope really helps a lot or else I would have stopped long ago.
I've been into diy audio since about 1967. As far as I can recall, the average age of the diyer or hi-fi nut was always somewhere in his 50s. I used to be the young one, now I'm right in the bell curve.
I'm 69, learned that I am color deficient building my first Heathkit. Been into audio since long before stereo was introduced. I don't build a lot, but dabble with my OrangePi crossover/player and enjoy music.
I'm kind of disappointed that no one above 81 has clocked in yet.
That's possibly because most have clocked out ?
My dad (a heavy smoker) had his first heart attack 46. I am 60 (non smoker)and not had my first yet. My mother (a heavy smoker) got cancer in her late 60's and died at 72.
We only have one body and need to look after it.
Trouble is with old age is failing eye sight and shaky hands.
I wear reading glasses to solder and have to hold my hand against the bench while soldering.
Trouble is with old age is failing eye sight and shaky hands. I wear reading glasses
Have you tried swearing off caffeine?
Not to mention that most probably only hear sea shells by the sea shore by that age. Kinda defeats the point of audio. But still come on... would've thought there would be at least one that age around here.
I don't drink much coffee.
I drink some coke and Dr. Pepper.
Probably early stages dementia or Parkinsons.
I do have memory problems, I remember faces but not names.
Dementia does run in the family.
That's why I try to keep mentally physically active.
To try and slow down the inevitable.
Everyone loves a 69'er
One of my college professors commented on the ironic situation for many audio enthusiasts.
"By the time you have enough money to buy the audio gear that you want, your hearing probably isn't good enough to enjoy it fully."
It's too bad that I didn't find the diy path until I was in my 30's. My system has finally stabilized, but it took a couple of decades to learn enough to do it. For most things, I saved a significant amount of money, but it still took a bit of time. But the journey has been enjoyable, with a great deal of satisfaction.
btw, I have no plans to quit yet! 😀
Hard to say, I'm hoping that if the deterioration is gradual the normalisation is too, it's understanding speech that is the problem, music can still be enjoyedNot to mention that most probably only hear sea shells by the sea shore by that age. Kinda defeats the point of audio.
I'm right up there with Nigel and Anatoliy, I've been involved in DIY since I was about 7, with increasing levels of competence as I got older.
My memories are somewhat different having spent time growing up both in the U.S. and what is now referred to as the E.U.
I'm a medical product design engineer in my real life and dabble in high end audio design on the side mostly as a hobby.
I can't see past the end of a paper bag these days so resort to all sorts of subterfuges including eyejusters (from the UK) and stacked readers (surprisingly effective). I wear progressives just for driving and walk around and recreate uncorrected.
I touched on memories, you see I remember PCBs and modular assemblies and built stuff on vector board and made really bad pcbs using phototransfer in my teens. I also did lots of P2P later on once I started designing and building my own tube gear.
I have just built one project based on a commercial design and did not like the result; the line stage section of the venerable ARC SP-3A. I also did my own phono stage design at that point mostly because I did not have parts to clone the 3A's phono stage, that phono stage was the progenitor for every phono stage I have designed since, the line stage design that replaced the one in the SP-3A was the basis for about a dozen or more line stages I built for others in the subsequent years until I started designing transformer coupled DHT designs.
I use a mix of through hole and SMD parts as it suits my design goals. I do restrict myself to 1206 and 0805 passives where possible, and sot-23, SOIC-8, 14 and 16, but will use tssop and ssop packages if I need to. Most of my new designs mix smd with vacuum tubes.
I have started designing my own PCBs recently, turns out I have more of a knack for it than I thought.
My goal is to continue to do this for as long as I breath... My hobby doesn't quite pay for itself, but I hope to carry that a bit further after two failed attempts at the audio business in the early 1990s and early 2000s.
You remember how old you are, that's goodProbably early stages dementia or Parkinsons.
My hearing is a bit strange. It tests to 9KHz. I find with certain voices I can hear the sound but cant convert to words in my head.
I am a "Charmed" fan and really struggle understanding Shannen Doherty.
The other actors are fine but with Shannen its just a noise. I have to turn the TV up to understand her.
<snip>
Don't get too discouraged, unless you experience severe hearing loss or tinitus you will not be aware of the HF hearing acuity loss unless you go looking for it deliberately. Most of the music does not live in the last octave, I enjoy the considerably better gear I can afford to design and build or purchase as desired just as much as I did 40 years ago. I think I also have a much greater sense of what is important to me and know much more about critical listening. (I was on the listening panel of a notorious mid fi company I worked for for about 7 years until I left their employment to loose my shirt in my own audio business)
Unfortunately a lot of kids ruin their hearing by their early 20s - I have met a number who are deafer than I am.. LOL
Stop all coffee, tea, and any kind of chocolate for a week, and see what happens.
If I eat any chocolate, I can't sleep.
The best thing we all can do it to protect out hearing.
Preserve what you have so you can enjoy listening to music longer.
I even wear hearing protection when I go into loud server rooms at work.
I work in a noisy factory and wear ear protection most of the time, most people don't, some of the youngsters shout and don't know they are. When it's not too loud I take them off and the noise masks my tinnitus a bit
- Member Areas
- The Lounge
- How old are you - DIYers?
