prorms said:
i clear up the problem my guitar was not gettting any power form the preamp i put 2 resistors to vcc and vss or v+ and v-
give it 600mv what difference thier value 2.2m at the very start of the circuit as long as dont give amperage will burn out the coils
make sure connect guitar cable the postive to the circuit and ground to the ground the powersupply i have has a postive and a negetive and a ground before get horible hiss noise when the guitar volume was turn about 1/2 way when guitar is hookup to the preamp the meter only reads 5 mv
I've tried Babelfish in all known languages (and Welsh) and still cannot work out what he means!
I'm not sure but I think he may have solved his original question in post 1 and created another?
"I clear up the problem."
"My guitar was not getting any power form [from] the preamp."
"I put 2 resistors to vcc and vss or v+ and v- [to] give it 600mv."
gobbledegook
"The power supply I have has a positve and a negative and a ground."
"before get horible hiss noise when the guitar volume was turn about 1/2 way"
"when guitar is hookup to the preamp the meter only reads 5 mv"
Give up...
Andy
