When I'm selecting parts, is there any benefit for seeking out tight tolerance versions? Is getting 1% resistors functionally better than 5%?
A boffin at LIGO found temperature coefficient and manufacturer can be useful predictors of resistor noise:
https://dcc.ligo.org/public/0002/T0900200/001/current_noise.pdf
My apologies to you.I don't understand what you mean
This LM317 datasheet in front of me uses the word "tolerance" twice.
The second use is "ESD tolerance."
The first is "Guaranteed 1% output voltage tolerance."
I've used only 1% metal film resistors (if the power level allows) for many years.
And you can hear a difference, so try it for yourself, no DBT is needed.
You can hear a difference between a 1% tolerance and 5% if there the same resistance?
And if there not, as stated before, it depends where you use them.
That meant metal film vs other types.
But, using 5% parts in an RIAA network instead of 1% parts would be audible,
especially for their worst case deviations between channels. And in a stereo attenuator as well.
Yes, using 5% resistors in both channels to set the gains can have a worst case imbalance error
of about 20% (1.6dB) between the channels.
I get a resistive divider will have worst case of 10%. But resistors from the same batch are usually within less than 1% of each other then the channel imbalance is much less.
For DIY you can measure them and adjust for the few places where tolerance matters.
But as has been said 1% aren't expensive so use them.
One cannot assume that 1% resistors will be better than their rating. Good design includes the worst case.
In any event, buying less than a case or a reel at a time does not imply they will be from the same batch,
or even the same year, of production.
Well ... all and good, but I once was quite happy with a whole collection of 5%, 2% and 1% resistors; however, not being a trusting kind of electronic geek, for any application benefitting from 'better balancing' (of say a pair of the lil' devils), I'd just fire up the 4-1/2 digit scope and measure a handful. Say for that LM317 circuit cited above. First hook it up on a breadboard with run-of-the-mill values, and suss out the regulated voltage. Substitute in one (or the other) resistors from 'the pile' until it is much closer to the ideal value. MAX, a minute of fiddling or two.
Just saying...
GoatGuy
Just saying...
GoatGuy
- Design & Build
- Parts
- How much do tolerance levels matter?
