How much did you spend on your last audio-related DIY project
How much did you spend (in USD) on your latest audio-related DIY project?
  • Less than $50
    Votes: 2 10.5%
  • $50-99
    Votes: 0 0.0%
  • $100-199
    Votes: 2 10.5%
  • $200-299
    Votes: 2 10.5%
  • $300-399
    Votes: 3 15.8%
  • $400-499
    Votes: 0 0.0%
  • $500-999
    Votes: 6 31.6%
  • $1000-1999
    Votes: 2 10.5%
  • $2000 or more
    Votes: 2 10.5%
  • Total voters
    19
My vote consists of;
Two TB W5-2143 drivers from ebay, $70. A specific can of paint, $30. Misc wood, paint roller $10. Should end up with a usable MLTL full range speaker set, with benefits - which I'll explain after I finish them in the TABAQ for Tangband thread.
I wonder what a poll would be like for the estimated fair technical labor savings (i.e. woodworking, metalworking, electronic construction, fit and finish detailing) by doing it DIY? I wouldnt want to pay someone else to do the work I'm putting into these things...
Does using parts from your stash count?
If not my last project cost $55-. If I count them do I use cost price or replacement cost??
4 * 200mm woofers/ 2 * 135mm midranges and 2 * 25mm low resonance tweeters and an asymmetrical XO for which I had to send $55- on a couple of iron cored inductors
Tom,
My last project was a speaker driver upgrade/retrofit that cost about $300 CAD.
Before that, a tube amp project that I have at least $750 CAD into.
Those are my two major projects since this time last year. A few other things but nothing major.
I have another amp build, and at least two separate speaker builds I hope to do this year. They'll cost a lot less, however, because I have most of the parts already. Realistically, I'll likely still end up spending a few hundred on various stuff.
I actually finish a small fraction of projects, each one usually hundreds of $. So, whilst I can pick a couple of projects which were around $500 (stereo amp) to $800 (mono speaker) I’ve likely spent a few thousand $ over the years to end up with these two working items.
I avoid taking shortcuts by buying kits or modules even if they would have saved time and money because that’s just not the reason I’m doing DIY. The main shortcuts I have taken are all about buying finished used commercial items off eBay (e.g. Marantz receiver, PMC speaker, turntable).
End result - my basement is full of stuff not doing much!
Hi Tom,
I started a new pair of 3-way speakers last spring. Cabinet materials and crossovers are somewhere between $600-$800 (USD). The drivers were in my stash, but I suppose the cost of equivalent ones today would probably be another $300-$400. (my vote above was for the 500-999 range).
However, other times, I can stay under $200 total for a smaller 2-way project.
Last project was 3 channels of ICE power - 1x 200ASC & 2x 200AC, and custom Ghent Audio chassis. Altogether came close to $900Cdn, but it’s working like a charm driving the front row in my 7.1 rig. I also have two channels of older model of Hypex UCD180 powering subs, and prefer the ICE for the wider bandwidth of the front row.
Been very happy with Mod286 Kit from Tom in upstairs system, and have thought about maybe going for 4 channels of Mod186 for the remaining HT surrounds, ‘cause, like as long as they’re actually operating, a guy can’t have too many amps, right?
Currently building a set of micro towers with four Mark Audio pulvia 7 HD drivers. Started because of a thread here and drivers were on sale. $160 for drivers $22 for sheet of 15mm BB. These drivers are deeper with wider magnets than the ones the plans were drawn for. Now I am scrambling to make them fit. Maybe another $40 to $60 before I am done. Still a cheap project due to no crossovers and low cost drivers, So $220 to $240 for the pair.
I have built a lot of speakers during this pandemic. Cheapest have been $50 in drivers plus $30 in wood. I have used up almost all of the drivers that have been slumbering in the basement due to the release of the Pass Diy 6 -24 biamp crossover that you can build for about $120. Now I need more amps so I was on your site making a list.
They did cost a little over a grand apiece, for just the major components. A lot of the small stuff “that adds up” came from inventory. The next one will be a exercise in doing it on the cheap.
