Peter Daniel said:But don't worry, the difference is very subtle, nothing to be concerned really
I don't worry!
Since I got the 2 types, I'll be able to compare
Peter Daniel said:
I don't have much experience with 1541 cheap. All I did, was changing electrolytics, simplifying output stage and converting to non oversampling in my Marantz CD94. It sounded pretty good, but no match to TDA1543 based DAC with Marantz as a transport. This Marantz is a prettygood transport, and I noticed the CD-Pro to be only marginally better (a bit more resolution and better clarity).
I still remember how Marantz sounded with 1541 chips, both regular version and double crown. The latter is more refined, less harsh and pretty pleasing. 1543 seems to have better resolution and to be more neutral. I diodn't noticed anything special about the difference in bass (as Elso claims) but my current speakers don't reproduce the deepest bass, so maybe that's why.
But when I converted my Marantz to TDA 1543 DAC, using I2S, reclocking, clock, active discrete output and batteries, it became so much better player, that the previous version with TDA1541S2, doesn't even come close. So it's all the matter of implementing those two chips.
I'll be experimenting with double crown version soon.
PS: To answer your question, TDA1541 may be more refined and 1543 chip with stripe seems more refined too
Peter,
What exactly is your setup with the TDA1543? I know you use rudolf's output stage. But which clock? (Elso's?), which reclocking? (Guido Tent's synchronous one?) and what power supply?
Hi!
Because it´s the latest discussion on philips dac´s.....
Where do you place the TDA1545? it´s the latest part of the TDA154x line.... (Ok I own one, but I need a reason to try it or leave it in the box, currently I´m verrry short of time, so any comments are welcome)
btw, I´ve build some standalone DAC´s (they are: TDA1541a, TDA1543, Pcm56, PCM61) more and more I get the feeling that there is no "the best" - it depends on my mood, the daytime, listening to headphone or speakers..... and maybe the amount of beer i´ve drunken
What do you think about that?
I'm using Tent clock, as it fits nicely on Rudolf's board, synchronous reclocking, super pair output stage, Siemens MKV coupling caps. Power to output stage provided by two 12V Yuhasa batteries (no regulators). Power to digital section from 6V batteries and BB low drop regualtors (3 of them, one for clock, one for reclocking and one for DAC)Bricolo said:
Peter,
S2 Crown ?? vs 1543
Is the S2 crown chip the real deal in these reports of the 1543 equaling or surpassing the TDA 1541 double crown?? It seems most comparisons have been 1543 vs "Chinese" S2 Crown. Any old S2 vs 1543 ....the real deal comparisons?? Reliable observers have touted the TDA1541 as the best of the NOS capable chips.
Are we now ALL saying the 1543 is the best??
How many TDA1541A are needed in parallel to get away without output buffer?
That question bags me ever since I made a dac with 4xTDA1543 in parallel. What I want to a achieve is output of 2V or preferablly more with xy number TDA1541A in parallel with passive I/V conversion and nothing more. Is it possible?
Regards, Ivo
Regards, Ivo
Peter Daniel said:
I also tried paralleling 2 and 4 TDA1543 and the results where much inferior to using a single chip.
I have the oposite experience.
Comparing the single TDA1543 (active analog stage, with OPA627 or LM6171, similar to the datasheet implementation) to the TDA1541A on my Philips CD650 (with LM6172 op-amps), the single TDA1543 was clearly inferior.
Each time I added a TDA1543 the sound got clearly better.
I tried 1, 2, 3, and settled with 4 chips.
After all, the TDA1543 is, in Philips' own words, an "economy version", isn't it?
The 1543 specs are worse.
1541 got decoupling caps, 1543 don't need it ?
I will try with 7 x 1541 S1.
Now my dealer try to get S2 for me, directly from Philips.
Re: S2 Crown ?? vs 1543
Except for Elso, I didn't notice anybody saying that All I was saying is that everything depends on implementation and the rest of the system.
Check this out. Some interesting discussions on paralleling 8 TDA1543s. Its a full project.
http://www.dddac.de/ma_dac22.htm
To my ears TDA1541A is still more refined even if compared against TDA1543 with stripe!Peter Daniel said:TDA1541 may be more refined and 1543 chip with stripe seems more refined too
Pedja
Pedja
Without proper context your previous quote is not true. To me refinement means nothing if the chip doesn't produce music
It is different topic if it means something or nothing. Refinement is refinement. I did not say TDA1541A is better… I said it is more refined.
Both TDA1541A and TDA1543 can produce music. They do it in a somewhat different ways though. Any preference Re these two chips is fine with me and this preference is probably more related to the general musical taste than anything else (assuming decent execution in both cases).
Pedja
Pedja
Pedja said:Both TDA1541A and TDA1543 can produce music. They do it in a somewhat different ways though. Any preference Re these two chips is fine with me and this preference is probably more related to the general musical taste than anything else (assuming decent execution in both cases).Pedja
Why not parallel 1541 and 1543 ?
So no more pain with choice
I have two Dacs inside my Philips CD650:
1. TDA1541A, NOS mode, LM6172 op-amps.
2. 4xTDA1543, NOS mode, 2xOPA627 active I/V (and independent Trafo/PSU).
I can A-B these things, because I have independent RCA outputs.
- Digital Source
- How many TDA1541A are needed in parallel to achieve double crown standard ?
