How low 6922/ECC88 can go?
Hi all,
Wanted to ask the tube expert about this schematic. I have problem with PS, so I wanted the tube section works in lower voltage.
How much lower the tube can go? I wanted the tube to be able to work in +/-2V p-p sinusoidal without defect or clipping. Will it go to +/-15V for the tube?
The tube will probably still handle the +/- 2V p2p but what you'll probably be feeding it is quite likely 2V RMS or put differently 6 V p2p.
With an effective B+ of 30V I'd expect some distortion with the 6DJ8/ECC88.
What you can try is use a 6GM8/ECC86 instead or otherwise explain us what the problem is you're experiencing with the GC.
Cheers,😉
Hi, fdgrove,
Yes, I wanted to take all kind of input without problem. Maybe there are CD player / preamp that have much output.
The datasheet of ECC88 have max voltage included, but not min voltage. I read somewhere that tubes cannot work in order with too low voltage. Just how much low voltage can the ECC88 works properly in this design? Is +/-35V is minimum, or it can go lower?
All I can get here is ECC88/6922. Also, I read somewhere that ECC86 does not sound so good.
Why I ask the question? I wanted to built this design into 2 possibilities. First the tubed gainclone. It is ok with the supply, since it is the same value.
Second to built a tubed preamp (replacing the gainclone with opamp). In this tubed preamp, the opamp needs only +/-15V, so to make things simple, could the tube take the same +/-15V also (or I will need other supply just for the tubes)
If it were me I'd go higher but not lower.
Have you considered using a voltage doubler as a powersupply?
It's not the best there is but short of adding another xformer it might save you a lot of hassle if your current xformer can handle it.
Also, have you put your question to mr Rasmussen himself?
Cheers,😉
But I take your answer is Higher, instead of Lower.
Higher than the +/- 15 VDC rail you suggest, yes.
I noticed you put the question to mr Rasmussen already.
What you need to work with tubes is an understanding of loadlines.
It's a little beyond the needs of what you're doing now but if you plan to work with tubes in the future you'll find it quite interesting.
Hope it was of help,😉
my last experiments with ecc88 show good behavior with power supply of +/-19V, FET cs with 2mA and Va ca 30V. (grid is about -10V). Maximum AC voltage thru buffer was ca 5Vpp.
Standard ECC88 buffer circuit (grid on 0VDC) can't work good on +/-15V PS, IMHO.
HI
At low voltage ECC86 sounds very good. In my op. better than
ecc88, e88cc,6922, pcc88 , 6dj8 etc.
I do not agree, these tubes work and sound rather good at low
voltage. The following cir, for instance, shows high dist.
at 2Vrms ( 0.5% about) but , irrespective to this, it sounds good.
Bye Federico
Hi, Moamps,
Do you have drawings on your schematic? I'm not quite understand it. The supply is +30V and -10V?
Hi, Federico,
I'm also confused with your drawing. The supply is floating and where is the output is taken.
What does the THD of 0.5% behave, if we use big rating power amp? Will it produce hiss, or distorted sound, or something else, or nothing?
in your design Va is ca 25V what is similar to my (30V).
I was referring to Joe's buffer schematic in +/-15V PS condition with grid tied to 0V where buffer can't work satisfactory, IMHO.
Next one...
I think Mr. Ernõ Borbély is a great expert of the low voltage tube amps. He wrote the ECC86 can easily work on+/-24V and even better with CCS! The ECC88 could be good too, but with a bit higher voltage :34-40V
Tyimo
