Re: Painting
A coat or two of good quality primer will suffice, with a light sanding between coats of course. 😉
Jolted_Chicken said:I'm going to paint my speaker box, will i need to seal the edges with the glue/water mixture?
Thanks for the Pinkmouse.
I've got more problems.
I'm going to paint the front baffle and veneer the rest with some Iron-on veneers. However, my wood work was quite shocking and the joins isnt flush. The exposed edge is lower than the joining side. This makes it very difficult to sand/plane.
Can I use putty to make the join flush?
if i use putty, will i need to seal the exposed edge before i apply the putty. After I apply the putty, will i need to seal that as well?
