Hi everyone, I am from New Zealand. Please forgive my poor English because I'm new immigrant here.😀
Currently, I spent a lot time studying the UCD classD amp. And plan to build a dual mono amp with two UCD400 using 2 SMPS both from hypex.
My question is, since the project will not be cheap, how good it will be£¿ Will it beat 1000-2000USD amps in the market?
And does it really wroth go for UCD400HG rathen than ST? And will liner power supplier sound better than SMPS?
Thanks. 😎
Thanks. 😎
Hi Ping.Shaki,
I built a amp based on the UcD400 modules. I wanted to build it as cheap as possible so all the other components were purchased/sourced in Australia. I think we share the same stores, Jaycar, Altronics etc...
Even though I built this on the cheap it is an excellent sounding, very powerful amp with low noise floor. Worth every cent.
http://minirig.org.au/2008/12/22/minirig-hypex-ucd400/
If you look at the last picture it has a bill of materials with cost breakdown.
col.
col.
Hi all.
I have 1 board UCD180ST use 2 mosfet STP14NF10 wrong, I has change by IRF 640 in to this board UCD but not uses.it very hot and osc about 100khz
Can you hepl my STP14NF10 or mosfet changer.
Thank you very much.
Hi Ping.Shaki,
Yes, Yes, and Yes.
I think it will easily beat $1k to $2k amps on the market. I also think you are much better off with the HG stuff, though I have not compared. (I have some standard 180's I need to wire up for surround amp duty)
I built a dual mono UCD400HG amp using linear supplies (a couple of 500VA toroids and the Hypex HG supplies). Similar to col, I bought everything besides the boards over 'here' (the US for me).
I also ended up ordering the hypex HxR's after the fact. The result is superb!
I recently had a chance to listen to it with some very expensive, very nice speakers and it sounded great there as well. I would say it seemed to get out of the way of the music quite well 😀
I used linear supplies mostly because I'm not sure SMPS is really ready for audio yet. I've never had a chance to listen to a good SMPS powered amp, so I could very well be wrong
(maybe one of these days I'll try it, for now I figured linear was a safer bet for better sound...)
Yes, Yes, and Yes.
I've got the Hypex SMPS supplies, and I'd say they're ready for audio. I haven't compared them to linear supplies, see no reason to really. The amps with the SMPS have nothing to apologize for. Quite amazing amplifiers. (and zero mechanical transformer hum, btw).
And I just finished one with a pair of older UcD400ST modules (the ones with OPA2134 SMD on the back) with a 625VA toroidal. Here it is with further bla bla bla:
Class-D Stereo Amplifier for Bass Drivers (Bi-amplification) « Ian's Projects
Hi Col.... 🙂
Hi Col.... 🙂
Hi Ian,
Have you done a head-to-head comparison/blind test involving a non-biased audience between your UcD400 and your Valve amp fullrange?
Rod's latest article exposing valve myths is great!
Valves - Myths
col.
Valves - Myths
col.
Hey Col,
I only finished building the amp last week. 🙂
Can you recommend such an audience? There is bias everywhere I look (including in the mirror). 😉
Seriously - no - the amp was built for bass use only and I like valve sound (distorted or otherwise) for mid and high.
Hey Col,
Orchestra musicians are great for audio blind testing, go and make some friends with your local orchestra.
col.
col,
you also use a TA3020 amp if I'm not mistaken. Do you care to elaborate on the sound differences between those amps? Your response will be appreciated - thx in advance.
col,
Hi Dubai2000,
Yes, I have a ConnexElectronic TA3020. I am powering it with a toroidal and PSU that I had from a UcD180 project that didn't get completed so power is lower than my UcD400. I haven't done any blind tests and I am not good at doing subjective comparisons. I prefer the engineers approach of comparing the spec. Both sound very good and the TA3020 is better bang4buck.
col.
Hi col,
thanks for your answer. I agree that the TA3020 is a great amp. Btw: I noticed on your website that you have not done any mods to your amp. In my experience its performance can be improved if a few caps are swapped.
Cheers
Cheers
Just for fun, I did a 150 Hz up listening comparison today between my Hypex UcD400ST amp and an old school Conrad Johnson MV55 valve amp in triode configuration (22W/channel). My test speaker set-up does not lend itself to a full-range comparison as the passive crossovers are hacked for active bi-amplification. To my ear, the CJ was immediately and unequivocally superior in terms of musicality and enjoyment. My Hypex amp sounds quite clean and precise, but lacks weight and sounds extremely "thin" and uninterestingly clinical compared to the CJ despite it being specified as having about ten times the power capability and much lower distortion figures. It performs reasonably well for bass frequencies, but nothing to write home about - again - to my ear - a little lacking in authoriy. A CJ MF2500A's bass performance is better on my set-up. I can't imagine capacitor or regulator changes making the modules sound less sterile. The problem might not be in the modules themselves, but in my implementation of them - but I doubt it. Next time, if I want to listen to a computer, I will. 🙂
Ian,
You demonstrate some interesting logic here, to have started with their worst version to save a dollar on your bass quality, after having presumed it wouldn't matter, and then judge the known compromised setup in full range use. According to your site you had it prejudged anyway, having said you'd never use it for full range, so this seems like a self fulfilling prophecy at least.
As icing on the cake you doubt improvements could make it better, and further doubt your own implementation is above reproach. It's not the worst I've seen but it can be improved, and your stock, standard grade modules, most certainly can.
Even were it relegated to bass I don't see why you'd use bog standard, cheap electrolytic coupling caps, and without even any bias across them. Of course, you've already concluded caps can't make a difference. It seems you have some work to do. Nothing of this is news, it shouldn't come as shock to you now.
Your computer comment makes the least sense of all, but it seems you're standing on your toes to make that reach. The problem is both the version of module you chose, and your use of them. You wouldn't garbage pick out of the dumpster of a five star restaurant and then write a bad review, or would you?
Since you know nothing of caps or anything and seem unwilling to make an effort you'd have done yourself well to pony up the extra money to get the high quality version, but bass doesn't matter, right?You'd do yourself well with a little bit of effort, and perhaps with the intent of seeing what is possible, rather than trying to prove your prejudice, of which you did an excellent job.
Must have hit a raw nerve, but clearly Plastic Boy either can't read or can't understand a logical expression of an alternative viewpoint, so what the heck.
For the benefit or others:
In his ill-tempered fit of bad manners with false presumptions and misinterpretations he missed my simple point which was that the sound (the way I hear it) of the cheap ST modules is already too clean and precise - which some/most people might like. My opinion (and I assume I am entitled to one) is that such a sound is clinical, thin and uninteresting and therefore certain so-called "upgrades" of caps and power supply regulators might make them sound even more clean and precise which would bother me. I'm allowed to express a doubt that they would have any effect and don't have to waste time and money on an experiment to prove an irrelevance.
IMO the ST modules are the appropriate choice (cost-wise) amongst the direct alternatives for bass application in a multi-amp set-up, or for subwoofers. Upgraded coupling caps and regulators (for a mere input buffer opamp!) would have no audible impact at these frequencies whatsoever. If PB were to do his homework, he might even learn that they are used by the manufacturer in their subwoofer plate amps. The reasons for that are clear and obvious to me.
BTW, my post started with "Just for fun" - so what is this about anyway?
I'm with you on that.
So it'd be wise to stick to that use and not for "150Hz up listening comparisons" or, at least, if you do so, don't jump into conclusions about what the higher grade modules can do.
... don't jump into conclusions about what the higher grade modules can do.
As far as I know, expressing a doubt is not the same as jumping to a conclusion.
Anyway, another point is that by the time you've spent the extra money on the higher grade modules (and even say the third party off-board regulator upgrades) and the very costly SMPS power supplies, you've moved right into and beyond the price realm of many proven alternatives, but still have a Class-D amp.
Say for bi-amping where you don't need high power for the upper range where the differences might be audible, then Class-A kits would have to jump out as logical contenders. And they could be repaired by people with ordinary diagnostic and soldering skills if something went wrong down the track. I don't know anybody who can repair a computer motherboard and the modules are just as packed.
For full range speakers with passive crossovers (i.e. just a single stereo amp), I concede that cost-wise, the ColdAmp modules or the Hypex UcD400HG etc. might be a logical starting point if you wanted that "clean" kind of sound and were prepared to regard them as disposable on failure.
...the very costly SMPS power supplies
Indeed, the Hypex SMPS power supplies are too expensive. Thankfully there are alternatives out there (and you can always go for a linear power supply).
Indeed.
But, trust me, I've seen (or actually, heard) many "proven alternatives" eat Hypex dust.
I have no idea about Coldamp but, in my experience, Hypex have excellent after-sales support.
Any suggestions as to alternative SMPS suppliers? Red Rocks are proving hard to get in contact with.
RedRocks are hard to contact nowadays. They must have shifted to bulk orders or something..
Check out connexelectronic (these guys have a thread in the vendor forum) or Coldamp. ClassDaudio will soon release their own SMPS. I'm sure others will have more suggestions.
- Class D
- How good a decent built UCD400 amp could be£¿Thanks.
