Does anyone know if this arm http://www.scheu-analogue.com/eng/tonearms/Cantus/Cantus_5.jpg actually pivots vertically, or does it just have a platform that the lifting arm raises so that the whole arm rises whilst staying horizontal?
If I'm correct, it would mean that this arm only uses a single bearing to allow the arm to pivot across the face of the LP. While it may mean that there's only one bearing, I don't think that this is of benfit considering that there must be serious stiction with an arm/tube combo that would be necessary to allow the arm to rise but have no play whilst on the LP.
I'm looking around at arm bearing schemes because I have a laser system with which I can cut acrylic and am thinking of making an arm from black or clear acrylic. I can't do the bearings so I'd need someone that can machine to partner on this project.
While I was looking around for ideas for an arm that I could cut from acrylic plate, I've also been looking to see if there are any smart bearing schemes that could be copied, hence my interest in this Sheu bearing.
TIA.
TIA.
