I was thinking of buying a pair of Tang Band W5-1138SMF to use as midbass drivers for my desktop speakers.
They claim 9,25mm of xmax, but nowhere does it say if it is one-way or two-way or by 70%Bl or by 50%BL.
Does anybody know how they measure it?
I also found Omnes audio SW 5.01 that looks similar but has one way Xmax of 7mm, which is either more or less depending on Tang Bands way of measuring.
If the Tang Band W5-1138SMF is consistent with the W3-2088SOF, it would be 9.24mm Xmax (18.5mm peak to peak) with Bl dropping to 70% of its maximum value.
https://audioxpress.com/article/test-bench-tang-band-w3-2088sof-micro-home-audio-subwoofer
