how does my sharp qa-1800 work
hmmmm, you must be a newbie.
You will need a 15 pin vga cable to hook up to your PC, they are usually quite cheap.
A remote control is absolutely essential for most panels, but I dont know about the sharp so you may may to scour ebay, typing in projection panel remote or sharp qa or something like that to get a remote control.
Search google as well on more instructions on how to set it up or scour these boards as well.
when I use my polaroid polaview 3000, I firstly switch off all equipment, connect it all, then power it up. THEN i power up the thing I'm going to use alongside with it like the pc or xbox. Also, with my panel, on my remote it has a black buton which when you press it it makes the screen go black. I dont know if your remote would have that if you had one. Try cleaning all connection, to remove rust or any dust and crud like that. Composites, from what I have read, always seem to be a problem, do the other connections work? s-video, vga?
