How do you reverse polarity with two woofers in parallel?
I’m getting a big dip I my response in my 3 way center.
The two 8ohm woofers ran in parallel are using one 8mh iron core inductor for the crossover and I’m thinking the polarity might be better flipped.
How do you flip the polarity on two drivers ran in parallel with an inductor on the positive leads coming out?
All of the speakers are ran out to the same red/black in this 3 way.
Do I just run the positive coming off the inductor into the whole system’s negative and negative into the whole systems positive?
The big dip is in the 200-700 range so I’m assuming these woofers are inverse of the midrange?
Reverse the midrange driver's polarity instead. If that works out, you may want to also reverse
the tweeter's polarity.
The woofers have to be connected in the same absolute polarity as the left and right woofers,
so keep the woofers the same.
This is the whole crossover
That's a second order crossover. The woofers have just an inductor in series, but the woofers' HF rolloff
combines with the inductor to make a second order filter as well. So when conecting the crossover,
reverse only the midrange phase. Connect the woofers and tweeter in positive phase, the same as the
left and right speakers..
The designer of that crossover said to not flip it on the speaker terminals but after the
crossover where all the other speakers connect to the binding posts. Does it matter ?
I think you misunderstood. The two wires between the crossover and the midrange driver
are the ones to flip. At either end is ok, but at the driver will be much easier.
Don't change anything else.
We mean the wires that actually connect to the mid driver terminals - those are the ones you swap around.
In other words, the wire that presently goes to the mid's positive terminal should be swapped to the mid's negative terminal and vice versa.
Geddit now? :happy1:
