How do you go about calculating Zout for a phono stage?
EDIT: actually, I should have said "calculating or measuring the Zout".
Can anybody tell me how I go about finding out what the output impedance of my JFET-based phono stage is? It has a BC547 as the output buffer, if that is relevant.
Thanks,
Andy
Measuring is easy: put a largish known resistor in series between the output of the stage and the output of a signal generator. Short the input of the stage, turn the signal generator up enough to get say 1 mA across your known resistor and measure the voltage to ground at the output (of the stage, not the generator). The output Z is the residual voltage at the stage output divided by the resistor current.
Calculating is easy if you post the schematic.
