Naw it's fine really.. the more information to soak up, the better!
I was planning on having some DC fans (regular 80mm computer case fans) as well, the Elmo has one for exhaust and I'll probably need a couple for the LCD when I get the whole split fresnel deal going.
I was looking around for power supplies and I happened to find this: Designed for Micro-AT it 's pretty small since if you look at the picture the fan on the back is 60mm. It's also only CAN$5 or US$3.25
You can find info about it here: http://www.a1parts.com/surplus/index.html#50wpsu
The good thing is that this place is in Toronto too.. and they have a store, so no shipping 🙂 I was also planning to get some heatshrink tubing and see what else they have.
I realize you can just pull one for free somewhere, but I like the small size of this one. Let me know what you guys think,
-rep
-rep
Do these computer power supplies work without the "motherboard connector" connected to anything? Never tried it so I was just wondering.
man, everyone here has a one track mind. a thread can morph into other ideas as it develops you know. it doesnt have to end with the same idea as it started. and.... he ended up going the p/s route. so i guess it wasnt a bad idea after all....
I'm gonna go with the PS for the DC fans, but I'm still going to try to go with the AC fan too since I already have it and it looks like it's gonna move a decent amount of air. I'm hoping to put my ballast and power supply inside the OHP (gonna check temperatures first once I get all the equip) so I want a good amount of air moving through the OHP.
-rep
-rep
sadd3j said:I was wondering how I hook this fan up so that it'll run (what power supply if I need one, how to wire it.. etc).
I have the original "big" fan from the Elmo, as in not the regular DC computer fans. I have no clue about electrical stuff so I don't know how I'd go about wiring this sucker up. If you check the PDF file it shows you the two power prongs that you use to power it.
http://www.nmb-europe.com/pdfs/airmovers/4715MS.PDF
Here are more stats on the fan:
model: B30-A00
voltage: 115V ~ AC
power (w): 10,0
current (mA): 140
rpm: 2600
noise: 37dBA
Thanks in advance,
-rep
Äãµ½µ×ÊǼÓÄôóÈË»¹ÊÇÏã¸ÛÈË£¿
ÕâÖÖ·çÉȹãÖÝ´ó°Ñ£¬Ê®ÎÄÒÔÄÚÒ»Ö»£¬ºÎ±ØÓÃ110VÄÇôÂé·³£¡
