How do I make a volume control for a electret mike
Hi, sorry if this is in the wrong section,
I just finished this 3 stage FM transmitter kit (from jaycar), and it works awesome as a bug but its too sensitive for a mic and keeps clipping.(I want to stick it inside my guitar) Do you guys know a good way of putting a volume control on an electret mike?
here is the input circuit
[/IMG]
Do you think this would work? If so, what value of potentiometer would work best? Would the reduced impedance change the frequency response of the mic?
thanks
You could,
Use a FET as a source follower, followed by a volume control. You need a buffer amp with a high input impedance with a condensor mic. You say at the start you want less gain not more.
Or use a suitable OpAmp if you have the appropriate supply, and don't forget that the output from a mic capsule can be very much higher than you might think on loud transients.
Thanks a lot for the replies.
Ill try the emitter resistor first, (more linearity sounds nice!) Ill just jam a small 50k multi turn trimpot between the transistor and the track..hope I dont fry the transistor while soldering it on, I left the legs too short!
