How do I : Join two FFC cables together?
Okay I have a few questions..
1. What is Pitch? ON the FFC cable?
2. What's conductor strand?
3. Does sheilding matter?
4. How do I pick Conductor Size?
I'm going to get my monitor, take it apart, count the # of pins on the FFC cable that's too short and then try to lengthen it. I'm guessing I'm going to need a two way zero insertion pressure connector but there's no pictures and I don't want to get something i dont need... help?
checked www.mouser.com for the electronics...
Pitch is how far apart the wires are. So if you have 20 wires and the ribbon is 20mm wide, you have a pitch of 1mm.
Don't worry about shielding. I'm not sure about conductor strand. I'd have to look it up. Check this out:
https://secure.lumenlab.com/shop/group.php?id=6
That's the Lumen Lab site with the extensions. Here is my setup:
The white ribbon is the FFC extension and the tiny latch the ribbon is connected to is the connector. LL supplies the connector with the ribbon.
