Now I need a circuit with low current : EL34 35W PP amplifier !!!
But general designer often used 30-60 mA for bias them, I get some idea from Berning Tube Amplifier EA-230 which used 3 mA each power tube (6JN6)
If possibly with EL34, How do I ?
Regard
analog guy
Regard
analog guy
The Berning amp uses sweep tubes and screen grid drive. It also runs right at the edge of class B, hence the low idle current. The peak current will still be as high as a conventional class AB amp. I have tried this with other sweep tubes (6AV5's) and it works quite well. Screen grid drive requires a tube with a sensitive screen grid. This can often be determined by the maximum screen grid voltage, the lower the better. An EL-34 won't work here.
To get a low idle current, you must operate close to class B , this requires a tube that is linear at very low currents. I haven't tried it, but again I don't think that an EL-34 will work here.
I have. It doesn't.
On the bright side, suitable sweep tubes like the 6JN6 that Berning used are cheaper than good EL34s and readily available. I just got a few dozen of them for $5 each, new in box.
OK, I need some suggestion about sgreen grid drive
Thanks SY for your reply, I look at Berning EA-2100 they used 6LF6 for tube power but I need some help if I use EL509 instead of 6LF6, How do I set current bias and How many watts does it has ? (250V Plate, 10mA bias)
Regard
analog guy
Regard
analog guy
Nobody here?
I searching a lot of EL509's link, but I can't understand different of control grid drive & sgreen grid drive.
Please me some link if you known.
analog guy
analog guy
6LF6 are unobtanium these days. Take a look at the EA2101 schematic where Berning used paralleled 6JN6.
His schematics are a great tutorial on how to do screen drive. Optimal idle currents vary with load impedance, particular tube used, plate voltage and the like. You'll need to determine it experimentally. Figure it will be between 2 and 10mA.
Someone suggest me, please
I decide to use EL519 for amplifier project in stead of 6LF6 of Berning EA-2100 but I have something wrong, It used 10mA each power tube !!! 100WRMS ?!?
How do I design OPT ?
: 700V Plate, 10mA bias, 100WRMS ?
: K of OPT?
: Henry of Primary & Secondary ?
: Wire size, Turn ratio ?
Regard
analog guy
: K of OPT?
Regard
analog guy
Please me
Does anyone have EL509/519 6LF6 on hand ?
I need 4 tubes and sockets, my car tube amplifier coming soon with screen drive circuit.
analog guy
analog guy
How much power do you want in your car amp. I used the 6AV5 in a screen drive amp that delivered 80 watts RMS at clip and 3% distortion at 50 watts with no feedback anywhere in the amp. 6AV5's are under $5 each in most tube stores and they fit an octal socket. There is a 12 volt version the 12AV5. They are available on Ebay for $1.50 each!
The amplifier runs at a B+ level of 550 volts and uses a 6600 ohm output transformer. The idle current is low, about 10 mA per tube I think. Just remember that the amp will draw about 200 mA per channel at full crank. Your power supply should be able to supply this much on signal peaks.
My amp is still in the prototype stage, but can be seen here. It is at the bottom of the page.
http://www.tubelab.com/6AV5.htm
Thanks Mr.Tubelab.com
I need more 50 WRMS for drive my Dynaudio MW150 5.75" midbass,
How do I design 80W with 6AV5 PP in screen grid drive ?
1.Schematic ?
2.Voltage ?
3.Bias ?
4.OPT ?
Thanks very much
analog guy
1.Schematic ?
2.Voltage ?
3.Bias ?
4.OPT ?
Thanks very much
analog guy
New project completed
EL509 sgreen drive enchance triode PP
+720 Vp
+360 cathode follower drive
+300 pre drive
-145 grid bias
10mA idle !!!
I used schematic of Berning EA-2100 but I used EL509 instead of 6LF6
Next time I'll design PCB of SMPS for use it in my car (100WRMS per channel !!!)
...Good impact bass (not aggressive) and widely sound stage that I never heard from other PP amplifier...
+720 Vp
+300 pre drive
-145 grid bias
10mA idle !!!
Tube bias?
Hi, Gents:
We don't need to care about what type of tubes? AF, RF, Osc, Horizontal output, Vertical. output-----etc.
When we want to use a tube, we must know where do you want the tube to work on? To utilize a tube, we must have it's EG-IP curve, If for class A SE, then you bias the tube to it's linear est district, if for AB PP, set the bias according to AB1, AB2, or B requirement. If set the quiescent current too low, the tube will work on class B, or below. Then crossover distortion become large. If U set the EL34 to a few ma, then u will get extreme distortion due to class B gets most power and most distortion.
If the quiescent current too low, you have to rise up the B+, or set the bias lower, too little quiescent current just put the tube work on a nonlinear district, U won't get good sound out, and is not advised.
SOUND BETTER WITH RIGHT QUIESCENT CURRENT
Hi, Gents:
ANALOG GUY said:If possibly with EL34, How do I ?
http://members.aol.com/sbench101
In a word: Loadlines
- Tubes / Valves
- How do I design minimum current for 35W PP AMP
