How difficult and expensive is to make PCB for your DAC?
From several years my practice here is to make PCB for every of my significant projects, including good Amps, DACs /any/ and other stuffs, like control and RF. Here the PCB's are relatively cheap to make in small quantities /1...5/ and I usually hate the "Evroboard" designs /except for the supply Caps in my amp, where the 1.5sqmm wires are defenitely much more than a wide soldered trace/.
In your country, do they /PCB manifacturers/ make small quantities of PCBs??
Is someone interested in making some "universal" DAC boards /supporting more than one type of DR, SRC , DAC, Analog, Supply and Clocks/???
Thanks a lot!😉
Thanks a lot!😉
For my knowledge in your country momentaly are slow price for boards in region and generaly better work condition from my country. Profesional company make in little serie too. Audio have another problem with request customers and now usually make little serie to 10 pcs.
Please don`t loose wish
:nod:
analog_sa said:
Are you proposing to manufacture prototyping boards? I am sure there will be a lot of interest. Do you already have a design in mind?
Yes, some kind of semi-universal prototyping boards - say AD 1955 board, PCM 1792 board, universal "mother board", PSU boards, etc.
Some /but a very few
:xeye: / people here will also be interested.
Sorry for this late answer!!!
Thanks a lot!😉
You would probably find that not too many people would be interested in them.
It would be very hard to design a board that support multiple DACs, etc that also has short tracks, enough room for different component sizes, etc.
You would be better off learning how to make your own PCBs.
I make my own double sided boards with no special equiptment for a very minimal cost... the only problem is it takes time (about 2 hrs for a decent sized board).
you might want to consider purchasing a demonstator board. Crystal and BB have them available, various distributors carry them. Jumpers/ dip switches set modes, etc. Seems like it will cost about the same as buying all the parts without the hassle of making a board and soldering smd components. I'll probably go that route when I get to DAC projects.
BB data sheet for the PCM 1704 board includes board patterns if you want to try making your own.
Machinow,
You lucky cheese, living in a country that make cheap PCB's. 😎
What about:
PCB PROTO PANEL SSS - $21,00 USD
SINGLE SIDE EURO FORMAT PCB 160 mm x 100 mm (6.3" x 3.9")
PCB PROTO PANEL DSQ - $104,00 USD
DOUBLE SIDE PCB PANEL 320 mm x 200 mm (12.6" x 7.8")
Cheap PCB's
