the one I have access to is off by .7ohm I need to replace a 3ohm one but I cannot find anything close. if I parallel resistors to get the right wattage, the closest I can get is 3.7ohm (measured using meter)
It depends where it is used. It can make a difference. You probably should try one or two alternatives and judge for yourself.
You should look better ;-)
https://www.mouser.be/c/passive-com.../resistors/through-hole-resistors|~Resistance
Seriously, it all depends where it's at. A schematic would help to judge importance of exact value.
Jan
Jan
