I will make this preamp:
http://web.telecom.cz/macura/dispre_en.html
So my question is:
How can I integrate a Baxandall Tone Control in this circuit?
So my question is:
I think the best way to it, is to put the tone controls before the shown preamp circuit...... Maybe put a buffer in before the controls to minimize influence 🙂
I tought the same, but I asked the question because I wonder if there maybe is a trick to put in the tone controls in the existing circuit.
I wouldn't fool around with Macura's circuits and integrate things such as a tone control........
Macura's work are very fine stuff 😉
It's better to have the controls in a separate circuit 😉
Yes, it is very fine stuff. There is only one thing missing; Tone Control. I think it is better to integrate it than have a lot of separate circuits. That means shorter signal-path.
What are you talking about 😕
You just need to put the tone control in the front of the preamp.... That won't result in a lot of circuits
However it's your choice 😉
It was not to
on you 😉
But keeping the tone control outside the preamp makes it much easier to mod and make changes to it later, and it's easier to fit a "Defeat" switch 😉
- How can I integrate a Baxandall Tone Control
