You can upload an avatar in your control panel. If you failed to do that recently, try again, there was an issue with the BBS that has been fixed.
dave
dave
OK, I found it.
To help the next user: to access the Control Panel you have to click the "Private messages" link, under the user name.
...to access the Control Panel you have to click the "Private messages" link, under the user name.
I think there is a direct way?
Up top, menu-bar, "User CP".
OK, WTF is a CP? -- Control Panel.
Follow the path in the Attached....
It is "direct" only if you see it -in the middle of 15 irrelevant menu items.I think there is a direct way?
One obvious usability "rule" is that relevant information should be put together. In this case, that is inside the box with the user name and the user information, and/or on the user name link as most users expect this, used to other forums. The info "You last visited: Today at 06:06 AM" is redundant. It could be put there, or after expanding the box to make room.
- Site
- Forum Problems & Feedback
- how can I add an avatar
