How calculate cathode LEDs biased
There is nothing to calculate. Once you determine desired voltage drop, which you do precisely the same way for any biasing method (by reading the number off the chart, given a pre-selected loadline) you pick a suitable LED (Vf of LED = -Vg of tube) and make sure you don't exceed its rated current for operation (which with preamplifier tube such as 6922 you won't).
Vg 6992 -1V?
Can you put an AC decoupling cap parallel with the LEDs?
In practicality there is no need, as a diode or LED will bypass all frequencies similar to a very big capacitor.
Any diode or LED can be used but the major factor between choosing them is a forward voltage drop. For example, a typical power diode like the 1N4007 has a drop of about 0.6v, a red LED is 1.5v, Green is 1.9v (estimated) while a zener may be 24v or so.
Choose the bias point in the typical way and match the diode need to the voltage across the cathode you want.
