Ladies and Gentlemen
Basing on alexw88's (shine7.com) experience, I've created my own project of PA150 (3xLM3886). It has been modified a bit, the size has been reduced, and some other tweaks have been made. I'd like to share the project with you (below). PDF file with switchable layers, try it! I'm gonna order the PCB soon, if anyone wants to grab a couple of PA150 PCB, let me know. Of course, tweaks still can be done before the order.
PCB layout:
http://airproject.drl.pl/PA150v18.pdf
PCB layout:
No picture, use the visualisation at the top of the page.
Power supply up to +35/-35 VDC. LM3886 datasheet.
Details: PA150 - 3x LM3886 PCB assembly guide
I has been well tested by alex88. Testing and measurement:
DIY BPA300 6x LM3886 300W audio Amplifier
It is still the same project, except the capacitors which were moved from the bottom to the top, C10 (10u) replaced with wima (better solution), and some downsizing.
For now:
syklab - 2 pcs
potepuh - 2 or 4 pcs
me - 2 pcs
and also on Polish dyi audio forums:
dekaenja - 2 pcs
kat01 - 2pcs
That is 10 or 12 altogether
The producer estimated the cost depending on quantity:
8 pieces - 10 EUR apiece
16 pieces - 7 EUR apiece
Anyone who is interested, just give me your e-mail address and I will send you some details.
syklab - 2 pcs
me - 2 pcs
dekaenja - 2 pcs
kat01 - 2pcs
