Horn loaded dome midrange
i have that dayton. i wanted to throw it out as soon as i tried it. i suppose if you open it up, put some damping in the chamber then use a $3,000 FIR digital crossover with 300db/oct lowpass on it then it will sound quite good !
Assuming this is stock, which I am quite sure it is, it appears to have plenty of damening material inside!
http://www.speakerdesign.net/dayton_rs/midrange/rs52/images/rs52_chamber_sliced.jpg
It also maintains low distortion down to very reasonable frequencies for a dome this size:
Zaph|Audio
Only issue is the breakup, which is to be expected with a metal dome.
Interesting result loaded with the 10" waveguide, seems to attenuate a lot of the upper mid range response with respect to the rest though.
I still wonder if the Tangband 50-1426SA could be used from 500hz and up in the horn below, with 6 db/octave HP at 15 khz or so to deal with the horn loading. :boggled:
i wonder if anybody except GOTO unit makes low midrange compression drivers ?
i would probably never buy GOTO unit even if i could afford it. it just looks like a rip off.
with drivers like Beyma TPL you pay for performance. it costs 10 times as much as a regular tweeter and it gives you 10 times the performance. same with a TAD compression driver.
but nobody seems to seriously approach compression midranges ...
The reason that it's not easy to buy a compression driver to cover the midrange is that it's a lot cheaper to simply build your own. For instance, you can spend $200-$1000 on a compression driver that will play down to 200hz. Or you can build your own for $20-$40.
For instance, the lowly Tangband W2-852SH makes a fine horn driver.
http://www.diyaudio.com/forums/multi-way/88237-suitable-midrange-cone-bandpass-mid-unity-horn-4.html
All the math you need to know can be found here:
Horn Theory
If you have any question on how to build a midrange horn, or horn load an array, let me know.
