horisontally mounted sub possible?
Hi folks,
As (probably) so many others, I have a spouse and a home theatre setup (with the compromises that may bring! 😀 )
To achieve high Spouse Acceptance Factor, I am considering to make a sub that will fit under my sofa. Befind the front frame, there's about 20 - 25 cm free height. Would it be possible to make a wide, but fairly flat anclosure, and then mount the woofers of this sub horisontally?
Would they sink in, so the membrane movement would be asymmetrically limited (pardon my language, but occasionally I lack the right words.)
Alternatively, the drivers would be placed in a 25 cm deep cabinet behind the sofa. The drivers would then be mounted the usual way, but be fairly close to the rear lining of the sofa. If vented, the ports could go in either direction.
I have a DIY amp with 2 x 80W / 8ohm channels to use. It's made over-kill for the rating as it's designed to be stable at continuous full power when bridged. I also consider using two 8 ohm drivers in parallel.
Any comments appreciated.
Thanks -
Jennice
Oh.. I forgot:
Currently I have a pair of elderly B&W 630 speakers (2.5 way), and a room size of approx. 30-35 m2.
I'm quite happy with the sound, but It lacks the deepest rumble (with a punch) during movies.
Obviously, I'm looking for something with more capability than the main speakers which handle the bass at the moment.
Thanks-
Jennice
Whether a sub driver can be mounted firing up (or down) or not is dependent on the construction of that particular driver. Some have suspensions that cope well with such mountings, and some do not.
What driver do you have in mind?
As drivers I was considering some SLS 10 or SLS12 from Peerless.
From what I could see, these are 8 ohm drivers.
To make the best use ofg the amplification I have available, I was thinking of using two drivers in parallel, andusing a 80 W/ 8 ohm channel to get about 160W to them.
If needs be, I have 2 of these channels, so that I could have 4 woofers, iach in sets of 2 parallelled, giving 2 x 160W for the subs.
Would that make sense?
MartinQ: Is your plan to get the physical rumble by using it as the sofa frame, or do these ducts function as some sort of bass reflex ports?
Jennice
MartinQ said:
You mean something like this?
(excuse the fabric! 🙂
what dia are those woofers? Mr. Linkwitz would be proud. I hope it sounds as loud as it looks 🙂
Jennice, most 10" drivers can be mounted face up/down it is the larger drivers 12" and above that be trouble. in general I would say that u can mount most 6 or 8" drivers anyway u want, 15" and above should not be mounted face up /down and as far as 10-12" drivers go it makes best sense to email the manufacturer.
I used 12" woofers from Audio Concepts face down with no trouble but I got a wirtten letter from Mike Dzurko before I did that. It is not guarantee but most guys like Mike are so DIY friendly that they will sincerly let you know what their drivers can do or not do.
