i'm sorry if this is kind of an idiot question, but right now i'm trying to hook up the L and R to the jx92s by their terminals, but it won't sing.
the website suggest that connect them in series, so i put the L in between positive terminals of the speaker and the amps.
what did i do wrong?
btw,
Happy New Year Everybody, i hope everyone having a good time 😉
btw,
The resistor and choke are wired in parallel to each other. This network is then wired in series with the speaker.
Hi Henry
I'm also curious about the impact of the filter.
Jordans website states a combo of a 4 Ohm resistor with a 2mH coil.
All I can find are 3R9 resistors and a 2,2 mH coils.
Now the question is, can we deviate a little from the stated values or are they critical?
Walter
Walter
walter,
i just tried the filters last night, and i think it is horrible.
the filters sucked the air very badly, and the sound is becoming bass dominant, i don't know if it works with original VTL design (mine is MLTL GM's)
btw, the inductor is 1,5 mH and 2 mH, tried both of them, and same results, and yes i can only get 3,9 ohms lynx (can't get those caddock).
then i tried with mundorf foil 0,2 mH, i think i hear a slight bass improvement, but because i only have one, so i only hear them in my right speaker.
i think i'm going to tried with 0,5 mH and up, to see if they sound good.
why don't u try them walter?
cheers
henry
cheers
henry
Hi Henry
For the moment I don't have the right resistors and only 0,39mH foil coils.
But rest asure, I will test it in the near future.
Cheers
Cheers
hi all,
latest update on my speaker, just change internal wiring with kimber 4tc, i use 2 of them for each runs.
sounds very open with solid vocals, i think i like it.
but the bass still shy, mids are still dominant.
just tried the 0,2 mH again today, and i noticing a slight bass improvement, but there is a noticable peak in the mids.
still haven't found the good setup.
cheers
cheers
- Full Range
- hooking up passive net on jx92s
