Hook-up wire
I recently soldered together my first electronics project, an lm3886 briangt kit. I am at he point where I am ready to make my connections to my xformer, inputs and speaker connections, but I need some quick info about wire before I proceed. I have no idea what type of wire to use for my hookups, as there seems to be a multitude of options.
A. What gauge?
B. Stranded or solid?
C. What material (copper, silver etc)?
D. Should I use the same type for all of my connections?
Thanks....this forum is great
I wouldn't worry too much about the wire. Regular 18gauge hook up wire should be fine. You can get thicker if you want but it makes soldering harder as the thick wire sucks up so much heat.
Stranded is best - it's flexible, less likely to fatigue, easy to form to terminals and can be crimped if need be.
Copper wire is plenty good, silver is a waste of good cash. (spend it on drivers instead🙂)
18g hookup is fine for power & speakers, use shielded cable for signal inputs.
One other thing, twist the power supply wires together so they are tightly grouped together. This will minimize stray magnetic field which can cause hum. Do the same for the speaker wires too.
Also - keep signal and power wires apart and if they have to cross each other, try to do that at 90 degrees angle.
But, considering my spaghetti mess, due to lack of space, it doesn't really matter that much how you lay them out, except if something is way too incorrect.
Wire quality is the last thing you should think about.
