homemalow pass filter ??'s
:cop:
AndrewT, that comment is against the rules and uncalled for. If you do not agree that a member is receiving the information given, then stay out of the thread. Same to the others.
binsky, it is recommended you pay closer attention to what the learned members are saying. You attitude can be very frustrating to those attempting to assist.
Thank you.
Binsky
The majority of the guys here are serious diy electronics builders and don't tolerate much really.
If you appear to want it on a plate and do no research before you pile in with a thousand questions they'll tell you in no uncertain terms.
I'm speaking from a bit of experience as I've done what you did - and not that long ago either !
If you take a look at the forums here you'll find out about the depth of the knowledge these people have and anyway you always end up learning something - which is good.
Apologies for my quip and good luck with your 2nd order sallen-key active low pass filter - I need to read up and find out what that means by the way 😉
Andrew
