home made system
Depending on your crossover frequency and any padding to match sensitivities the answer could well be yes.
It is common for tweeters to be more sensitive than woofers requiring a resistor in series (or resistive L-pad) This will reduce the power delivered to the tweeter.
If you are crossing over above 3KHz then the total power to the tweeter is small and you'll be OK.
Bottom line is it all depends how loud you turn it up. The worst thing for tweeters is the amp clipping as this converts all the LF energy for the woofer to HF energy to the tweeter.
Keep the volume down to start and monitor the AC voltage on the tweeter terminals with a good AC voltmeter. power=V^2/R. so for an 8ohm tweeter you don't want to see levels hitting 22Vrms
edit: by good I mean a voltmeter with 20KHz bandwidth - not all are.
At sane listening levels you should be OK. Typically, you need 20dB headroom to handle peaks so your 400W amplifier is good for 40W continuous programme. You don't say if the tweeter is 60W ave or 60Wpk or what kind of music or room you use it in. If this is for a nightclub or party sound system then I would say you could quite easily blow this tweeter.
Best way is to measure, then you know.
edit: it also depends on the order of the crossover. A 4th order will offer better protection than a 1st order.
