Home Built Infinity SM-155
Hello Everyone!
I am kind of green still and am looking for help on building a speaker that will be the same as an Infinity SM-155.
See specifications below:
Power Rating - 10-300 Watts
Frequency Response - 29Hz to 27kHz within +/- 3dB
Crossover Frequency - 500Hz / 5500Hz
Efficiency - 102 dB SPL, 1 Watt / 1 Meter
Impedance- Compatible with 4 to 8 Ohms
Driver - 1 x 15" Woofer, 2 x 4.5" Midrange, 1 x 1" Tweeter
Dimensions - 17.75" Wide, 40.25" High, 12.5" Deep
Tone controls (mid, tweeter), auto-reset circuit breaker protection (mid & tweeter)
Port - Tuned Rear
I need help with the following:
1) driver selection
2) enclosure construction
3) crossover schematic design
It would also be great if someone with these speakers could comment on if there is bracing in the original speakers and what the port dimensions are.
Also is it possible to use a front slot port versus a rear port?
Thank you in advance!
This will be hard to duplicate. Mainly because some of the specs are simply impossible.
These 2 comes to mind. Each on their own are maybe believable. BUT not both at the same time.
How Infinty managed too claim these numbers are beyond my understanding, but I guess it was too match CV`s equally bloated specs.
Hi FE3T,
Thank you for the information. Out of the two I would prefer to have the frequency response and sacrifice efficiency.
