I've been toying around with the idea of using home made inductors in my amp power to try and reduce ripple on the supply lines.
I was thinking of just winding some lacquered wire around a wooden bobin and using cable ties to hold it together - any suggestions on the dimensions and number of turns, etc? (also diameter of wire?).
I'm running a dual P3A amp with 41V (approx) rails.
The arrangement would be this:
Toroid>Bridge>Caps>Inductor>Amp
If my thinking is right this would create a high pass LC filter to ground, attenuating unwanted frequencies?
