Holtons Lateral Amp...HELP NEEDED!
It's difficult to say what is wrong, I have also built this amp with problems but this was my own mistakes.
So, you can not bias the positive rail so how about the negative rail?
Im my amp I did some extra, I lowered the gate resistor to 270 ohm and putted source resistors in the O/P stage on 0,22 ohm.
Check the connection of Q9 base to collector (I missed this one at first with strange effects in the amplifier.
For me I could not bias the amp to 200mA with the 200ohm trimmer so I changed to 470ohm instead
To search for more errors you can send me the drawing of the pcb or show it here if you want to
Bengt
