Joined 2009
Hi, I'm sorry if this was covered already but I have some off-axis measurements done in HOLMImpulse and would like to present them in a more readable fashion. I have trouble figuring out how to import those in another FREE software package such as Praxis that is able to display polar plots.
Yeah. That is an issue for Holm.
I tried importing into LEAP, but have yet to get it to work. I suspect that it is doable, but I just have not figured it out yet.
I don't have time to write a program to do it and I am looking at other software packages such as CLIO, but that will cost you money.
FWIW ( as a test ), I just exported ( from Holm ) the full IR ( of a single file-channel ) as a 24 bit PCM WAVE file .
That file format was then successfully imported in both, ARTA and REW ( sorry, I don't have Praxis to test out for you ) .
Within ARTA that single can then be saved ( once own ARTA ) as a single .pir ( ARTA ) file .
ARTA makes its polars by opening up a user defined batch of it's own singlular files .
Simply buy ARTA ( it's well worth its' minimalist price tag ).
<. EarlK
<. EarlK
Joined 2009
