thanks ernperkins, I will have a look
I do want to see what other people did with hivi domes for inspiration
otherwise I measure, I listen, I modify, and listen and measure again, and again, till I am happy
Goal is as simple as crossover as possible, as flat fr response as possible, as well as phase response...I found it important too
As I posted as the beginning of this thread, hivi mid dome and tweeter dome measure surprisingly well with just cap on each, so I am surprised to see such complicated crossovers in place
not sure why is that needed
anyway, I measured 5.5" peerless dome I selected, I did select it based on required range and that its dome too, and it measured quite well. My measurements are close to the published, its useful for 50hz to ~2khz, it has one break up at 3kz, no too severe, but something I need to suppress, so I am thinking of 2nd order at 1 kz, then I will measure again and listen
Unless you play them at very high spl or push the mid low, the simple filters work very well.
I've been restoring some old 3ways with this sort of setup- the Scott s-15s.
Crossed simply at 1&4k they have 5" CTS mids in cans, so the mid is loafing and the extra low frequencies are easily handled.
In these the tweeters are the limiting factors, and they play loud better with a steeper rolloff.
I'm watching this project of yours, have been playing with the widerange 3.5" dome that Mad has- with HDS 5.25 instead, but you have a great look with all domes.
I have always crossed Dayton domes at 900hz. Hivi will be at 1000hz. That should keep them happy. I never play hifi loud. That's what I have PA speakers for...
Exactly.
It's only those poor souls who must make one set of speakers do all jobs who have to worry.
I xovered the DMN-A at 850Hz, IIRC, and it needed the Fs suppression for the lower range to remain undistorted. The top-end needed the zobel to help with the blend of the mid to tweeter. The resistor across the tweeter damps its Fs. The 4.7 ohms are for level, and the rest is just slope/order and knee damping.
Later,
Wolf
Later,
Wolf
Kinda neat getting a mention on a site with someone else's design because I also used it. I've not heard of that guy either, but I do know of Rob Elder and Lou Corragio (RIP).
Hong Nguyen also used it with an old Vifa M26, IIRC, the one with the weird woven phasing-style dustcap.
Later,
Wolf
Later,
Wolf
thanks for the info wolf...
I will keep you guys posted with progress, just be patient, too many projects going on at the same time
but I want to finish this one to perfection
Previously I measured HiVi domes with just 30uF cap to protect...they measured well, but I want to cross the mid dome at 1kHz, not to load it too much. Tweeter dome will remain with 3uF cap, seems like very smooth transition between hivi domes.
So I lowered mid dome cap to 20uF, and used 2nd order filter.
This is how the Hivi domes measure now.
Pretty nice.
Pretty nice.
Ok, minor problem is the sensitivity. Peerless 5.5' midbass dome is not sensitive enough. HiVi domes are way more sensitive.
I knew about this, I selected peerless at 4 ohms, while HiVi domes are 7 ohms, so I was hoping to get closer to the sensitivities, but I was wrong. Hivi domes are way more sensitive than I expected.
Well, I can put L-pad on Hivi domes, or I can bi amp it, I do have spare minidsp, or I can select another midbass, I have 6fe200 around...so lots of options.
I will keep playing around to make it as flat as possible.
Btw, the 12" woofer on the picture is not used, it serves just as a stand.
I do plan to use sub eventually, but for now I concentrate on getting the 100Hz to 20kHz as flat as possible.
Cheers.
Cheers.
Looks good.
Did you make the new faceplate for the 2 domes ? You mentioned that you removed the original faceplates.
I did that to Dayton domes...I do not have pic now, but can make one later, once I am home.
Hivi domes are close enough.
I was referring to the faceplate in post#30 it integrates the two domes very nicely. Is that a stock item?
OK thanks, just found it, it's a "TM1A Midrange Tweeter" at Product information:TM1A Midrange Tweeter
and HiVi Tm1 Compact Midrange/tweeter Assembly
No longer generally available, but the faceplate drawings are useful.
Ok, I looked at the link...and it says mid dome impedance is 5 ohm, ok, I though it was 7. Slight difference, but it explains why the output level is higher as I was expecting.
Good to know.
Good to know.
- Hivi domes
