Hi
About the Kanada type amplifier.
NEC606 is sold as follows though it is uncertain whether to send out foreign countries. (it is EN not dollar )
http://www.wakamatsu-net.com/cgibin/biz/page.cgi?cate=1002&page=0
Moreover, Mr. Kanada is a writer of the following magazines.
http://www.seibundo-net.co.jp/CGI/search/list.cgi?key=z_sinkan&c_bunrui=Z04
DAC is announced recently.
It is only information because I do not actually confirm it though the kit is sold as follows.
http://ss5.inet-osaka.or.jp/~teksanyo/tksaudio.htm
It is said that real value will be demonstrated only after specified parts are used as for the Kanada type. Especially, resistance is severe. For another, wiring has specified twist etc
The other Kubota type all fet amp, 0dB Buffer amp,
Yasui type is good known inJapan by the magazine ,too.
REGARD
REGARD
P.S
LAST KUBOTA amp is this
http://www.d1.dion.ne.jp/~kubota_t/kubota-amp.html
Sorry not Speaking HITACH amp
REGARD
REGARD
Hello
First of all thank you for all of you all the highly valuable information ..
I just made a mistake before two post accidentally I hit the enter button (sorry about that) if is possible to remove that post please remove it .
Thank you very much .
For me replacement they offered me (they told the best would be )2SB631K from Sanyo .
Even military use that transistor in airplanes etc .
The only problem is when I finish the amplifier and may be the sound not my taste I would always will think because not the orig driver was used in the amp .
I will wait until maybe there will be the schematic from the all mosfet version . Let see if uses the same power mosfet and the 2SK117BL what I already I purchased .
Thanks to Mlloyd1 . In these case I think the best to buy the original parts an buy the replacement and test it with both .
Thanks to the Japanese fellow DIY-ers help to . Very good information .Even I see they store has the orig Hiraga transistors .
Greetings
Greetings
