Hi everyone,
Been a reader of this forum for a while, newly member. It's my first post here so please be gentle (hmmm that sounded weird). Bought a 15w hiraga kit from jims audio on ebay with NJW0302G / NJW0281G transistors. Yeah, that was the easy part.
Now for something completely different : the power supply. But before i put my soldering skills to work, i just need some validation from more expert sources just to know that i'm not missing something before i begin. So the PS would look like :
250VA toroidal Tsfo 18-0-18 secondary
25A rect. bridge
1x 68,000uF 25v first stage
1R 15W
2x 68,000 second stage
2,2 uF mkp
So... Am i totally off-track or in the ball park
If you need more infos , i'll gladly add it.
thanks again
25A rect. bridge
1R 15W
2,2 uF mkp
thanks again
Welcome mate. I cant help much other then that but I look forward to following your project as I am too wanting to build a pair to drive my jbl 2226H woofers in the bass of my horn set up. I usually build tubes but I think these amps will be far more affordable. I am sure if you search you will find more posts on this very old design but your build is well worthy of a new thread if you are going to document the project right through start to finish good luck!. as an after thought. Perhaps too much heat sink-age will be about enough.
Hi martinduchesne,
I finished my Hiraga 30Watts a month ago. I used a PSU from Per-Anders Sjostrom. Check out his webshop and the design of his PSU: SPS01. This PSU is perfect. If you follow those lines you'll be more than OK.
Sjoerd
Sjoerd
thanks for your reply,
my power supply looks like (per rails)
toroidal tx 15v secondary
retifiier
1 x 10,000uf caps
1R 25W
2 x 10,000 caps
2.2uf
approx 18VDC out to amplifier circuit
just waiting for my casing to assemble. Will post pictures when done with specs and etc...
retifiier
1 x 10,000uf caps
1R 25W
2 x 10,000 caps
2.2uf
Sorry i rushed the previous description.
My PSU design is loosly based on danw1million super class-a amplifier on diyaudioprojects with a lower output voltage. I think he "overkilled" the capacitor bank. I was also inspired by TNT-Audio PSU design course to calculate my capacitor bank needs and transformer power. Had a great deal on 2x 120VA toroidal transformers on newark.
So...one transformer for each channel. One channel shown :
For the amp section i used jim's audio on ebay kit. The supplier suggests a +-18V PSU output to feed the amp section. I have between 18-19V with my PSU.
15W Pure Sound Class A Amplifer Kit Hiraga | eBay
Any comments on this supplier ?
thanks
thanks
The original 8w Le Monstre asks for something like a minimum of 650,000uF of capacity for its supply. You can read the original articles here: The Class-A Amplifier Site - Jean Hiraga Index
I agree that is a crazy amount of capacitance, but it appears to be necessary for it to sound its best. I will be building one of these soon too, and I plan to use a capacitance multiplier for mine. Something along these lines: Capacitance Multiplier Power Supply Filter
I tried something like the Hiraga PSU. See bottom of page : The Class-A Amplifier Site - Hiraga 'The Monster'
Instead i used my 10,000uF caps (not 68,000uF) and 7.5R 20W (not 8R 10W). I could cook bacon on the resistors.
I dont wanna use screw type caps. Do you think those would make a good choice ?
ECE-T1EP683EA Panasonic Electronic Components | Mouser
- Hiraga : yet another design
