hijack Shark DSP chip Pioneer VSA AX10i
hi is it possible to reprogrammed somehow the dsp chip of my pioneer vsa ax10i to perform digital crossover and eq inside the unit then making use of the multichannel amplification and volume control .
I like my amp and am trying to find the best way to use it for an active multi channel speaker project . I was at first hoping to use a pc and send through optical to the dac now I've found out optical can't transit multiple channels in high quality audio I then though I might be able to make use of the firewire 400 input this model has ... that doesn't seem realistic so thinking about it today is there any way of using the dsp already in the receiver or some kind of USB converter to send the digital signal straight into the dsp chip inside
thanks James
