High voltage SS output, any experiences ?
Ex-Moderator R.I.P.
Joined 2005
While their not hybrids, I've built amps that are high voltage SS. The amps are solid state renditions of the 47 P-P and Tabor class A balanced amplifiers with local feedback on the output stage.
On my webpage-
Tube versions - 47 P-P, Tabor, Tabor Rev. 3
Solid State versions - SS Tabor
Here's another example of a SS high voltage output circuit with an OPT and local outstage feedback.
http://www.diyaudio.com/forums/tube...r-triode-strapped-pentode-12.html#post2207735
I started with a hybrid of MOSFET input and a 6L6 output tube, then for grins substituted a HV IGBT in place of the tube. I think it may sound a little better with the SS device but it's a difficult call.
For a hybrid, the depletion mode MOSFET at the input could be replaced with a pentode., which will certainly have the possibility of changing the low order harmonic content.
Michael
SS Tabor
Hi Gary
Very impressed with your SS Tabor amplifier.
I have built a few transformer coupled amplifiers Amity, Karna, KK and variants (all DHT outputs).
I have noticed the input tube has a big impact on the overall sonic of the amplifier and I just haven’t found an input tube I like.
What are your thoughts if I used SS input TT coupled to 45 drivers and 300B outputs? This would do away with a tube input.
regards
Frank
