What was the positive properties if you bear in mind that you don't have a grounded chassis?
Besides my thing was only the regulator.
You star ground the raw supply at its output, the Regulators and the audio circuit. The + or - leg becomes the output ground depending on which polarity you want. I've noticed an improvement in low level detail and "air" when I get rid of RF anywhere in a PS design. Galo and Jan Didden use this setup for the raw supply of any Super Reg they build.
Hi P-A,
I will buy variable regulated power supply for 50v , 20A rating. Can you make it modular ? So we can even make Lab style power supply with it?.
My first application for Pure CLASS A amplifier.
Thanks,
Alexk
toronto
Thanks,
Alexk
toronto
jacco that would be cool, all of us making amps that can weld, we could do group buys on audiophile crocodile clips, and super visors........
First: 20 A and 50 volts, have you thought this over? What kind of amp is this and what kind of load do you have?boxedin said:I will buy variable regulated power supply for 50v , 20A rating. Can you make it modular ? So we can even make Lab style power supply with it?.
This regulator will not be particulary well suited for lab power supply. You have quite different demands and ultra low noise and ultra high speed is massive overkill.
Some time has gone now and from what I can gather the interest isn't very big but nevertheless I think it's interesting as a challenge.
(I'm really puzzled by 20 A 50 V class A
How does such an amp look like?)
peranders said:How does such an amp look like?)
Big ?
I'm trying to get 500 to 600 watts out of the Krell Clones, and it is getting bigger and bigger.
Can only try to imagine how 2000 watts will be like.
Surprised too that there has not been much more response, i've read many post their wish for something that would be covered by your proposal, Per Anders.
peranders said:(I'm really puzzled by 20 A 50 V class AHow does such an amp look like?)
This will come close to doing it:
Quite frankly, a warm wife is better than a warm class A amplifier (although some may beg to differ).
"It" is an HP6129 high current power supply -- "it" will probably do 300-500 watts continuously, day and night for years -- these were used by the auto companies and aerospace. The design is basically a computer controlled (early 1980's) 15 bit DAC and voltage amplifier -- rails are +/- 95, with an additional windings for the operational amplifiers etc. I bought a bunch of them during the internet post-mortem -- the least expensive was $1.00 but I had to drive 2 hours to get it as the fellow wouldn't ship it. You can adjust each bit on the DAC manually.
jackinnj said:I bought a bunch of them
A BUNCH ??????????????????????
Shoot !
Too hot will kill you, Jack.
Re: tube
Because the Jung SuperRegulator uses a high speed op amp as an AD825 or AD797 "full blast" (without any compensation) it's not really likely that all of the impedance characteristics could be replicated -- I think that Janneman should opine.
you can lift the opamp above ground with Zener diodes -- as Audio Research did in their SP8 --
Jaap said:a superregulator for use in a tube amp would be great
Re: Re: tube
Let's say we have 7-15 volts voltage reference this mean that the DC gain will land between 3-10 and the AC gain down to 1. This will create _pretty_ low output impedance I'd say.jackinnj said:Because the Jung SuperRegulator uses a high speed op amp as an AD825 or AD797 "full blast" (without any compensation) it's not really likely that all of the impedance characteristics could be replicated
I'm not totally happy to introduce "noise generators" if I don't have to.jackinnj said:you can lift the opamp above ground with Zener diodes -- as Audio Research did in their SP8 --
i'm in
I am in for a super high voltage high current regulator. Something like 50V at 5-8 amps. If I pick up welding, maybe more.
Re: i'm in
I'm in for a Super Duper 100v regulator for the front end of a Super Leach. In case this regulator thing works out, GB or plans for selling PCBs from your homepage, Per Anders ?
lgreen said:I am in for a super high voltage high current regulator.
I'm just checking interest and I'll take it from there. Although I think it would be interesting with "more is better" the expressed interest seems not to be big, rather low actually.
- Group Buys
- High voltage, high current super regulator, possible group buy
