what does your pusle have to look like , i.e. shape and pressure.
Maybe you can just use some form of pressure-chamber and a tube in front of it.
Charles
Charles
I would go with an 18" PA driver with a large 4" voice coil, and as mentioned earlier a 4th order bandpass would be very good, you can get a serisously horrible (wonderfull in your case) peak)in a narrow range, 60 Hz would be very easy. Small sealed chamber and a large vented chamber with an appropriate vent. For a single frequency only, I am not sure if there is any EASIER enclosure to build....
And use a Variac as a source. infinetly adjustable and the most efficent thing out there if all you want is 60Hz.....
A venturi air mover might work for you.
http://www.airtxinternational.com/catalog/air_amplifiers.php?gclid=CIuQ9rO5lJECFQKHPAod7Fm6Qw
