Ohmite RJS2R0 Good deal, at half or less of the usual price.
2 Ohm 50W Rheostat Wirewound Resistor Potentiometer 50 Watt 2ohm Ohms | eBay
RJS2R0 Ohmite - Variable Resistors and Potentiometers - Distributors, Price Comparison, and Datasheets | Octopart component search
I know pots in a passive network are always undesirable but is that Ohmite one
considered decent and "audio" quality
You won't find a part like this that is any better than the Ohmite.
It may even be the only such part around these days.
Inductance in a 2 ohm wire wound pot is negligible, and will be well under 1uH.
First you have to found the exact value resistor and eliminate the pot as at long term is not useful .My tweeters have a ladder switch but i never touch it .
The 10R pots i have are similar to the ohmite , i much preferred the sound of a caddock thick film on a heatsink than the pot .
If you can find 0,1 R 3 or 5 W cheap resistors to make a string and find the right value maybe is a good way to begin before spending money
https://www.mouser.es/ProductDetail/TE-Connectivity/ROX3SJR10?qs=Im7Ui%2B8riBUQgLvYDfzsjQ==
20 resistors are 3€ and 40W for 2R I've done before and it's not bad sounding
once you get the value you buy something better .
- Design & Build
- Parts
- High quality 2 ohm pot for passive crossover
