Ok I’m getting 1 maybe 2 15” mtx thunder 9500 sub(s) and I need a high powered amp about 1kw rms @ 4 ohms to run the sub *for home use*; any suggestions?
What about the amp that the Aussieamps guy has made?
@ Aussieamps
Can I get a pre-etched pcb?
Where can I get the parts list?
Or is the amp still undergoing testing?
@ Aussieamps
You really want to build that amp?
$398.80 USD will get you a plate amp from:
http://www.partsexpress.com/pe/
showdetl.cfm?&DID=7&Partnumber=300-808
# High power Class AB output stage
# Full parametric bass EQ
# Phase reversal switch
# Auto On/Off
# Toroidal power supply transformer
# Power output: 512 watts RMS @ 8 ohms, 1024 watts RMS @ 4 ohms
# S/N ratio: 98 dB (A-weighted)
# Low-pass crossover: 30 - 200 Hz, 24 dB/octave
# Auto On/Off
The low end at 30 Hz is not so great on this amp tho.
And you would miss all the fun of building it.
Prosit
# Auto On/Off
# Auto On/Off
Prosit
acenovelty said:$398.80 USD
Up Side Down?
![dodgy :dodgy: :dodgy:](https://files.diyaudio.com/forums/images/smilies/dodgy.gif)
Universal Serial Dog?
![whazzat :whazzat: :whazzat:](https://files.diyaudio.com/forums/images/smilies/whazzat.gif)
Unusually Silly Discussion?
Under Secretary of Defense?
Unified School District?
University of San Diego?
University of South Dakota?
User Systems Diagram?
Nuh. It's got me beat...
Good old American greenback dollars.
George Washington on the $1 bill,
Abraham Lincoln on the $5 bill,
Alexander Hamilton on the $10 bill,
Andrew Jackson on the $20 bill,
Ulysses S. Grant on the $50 bill,
Benjamin Franklin on the $100 bill.
And now for the quiz.
Which of them was not a President of the US of A?
(Clue......only four were)
Circlotron, yur makin some fun at yur mate ain't yuh?
Not a fair quiz for you. Most Americans can't tell you
what the 2 non presidents are famous for .
Altho one of them is a famous kite flyer.
Prosit
Prosit
A second-hand pro amp is something else to consider (try music stores and pawn shops), or even a new Behringer. Once you price out transformers, caps and heat sinks and chassis, the made-in-China Behringer amps look like real bargains.
The EP2500 may actually be too much power, but it's less than $400 US. Or there's the EP1500: http://www.zzounds.com/item--BEHEP1500
I don't know if the U.S. amps can be easily wired for 220V/50Hz, if that's what you use in Australia. Zzounds doesn't ship outside the U.S., but there's some vendors on Ebay that will:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=23787&item=3754234719&rd=1
Of course, shipping and customs will add up to an unpleasant sum for something as expensive and heavy as a power amp...
Behringer has a poor reputation in the pro field. Running one at 4 ohm bridged isn't recommended. Personally, I would use a QSC RMX (esp the HD models which can handle 4 ohm bridged) or PLX amps.
If you have serious cash, there are a lot of great, powerful sub amps that would be killer at home, for example the Crown I-Tech, Powersoft Digam K-series, QSC powerlight, etc etc
Commentable Experienced Thoughts
UNIDENTIFIED SERIOUS DEVELOPMENT
Circlotron said:
Up Side Down?![]()
Universal Serial Dog?![]()
- High powered amp suggestions.
