Sorry for crossposting...
I got mine working sort of but only if I keep my finger on IC8 pin5 and the RST/UL pin which is for connecting the small boards... For now I will only use it for USB so I need to find what values theese pins should be set to for it to work (without the finger or the small boards 🙂 )
Brgds
Brgds
OK, 10k between 3V and RST made it. I dont understand how it is supposed to work as is with the WM8804 board since there is nothing on pin 4 of J2 (RST)...
Well it sounds quite good on a first impression. I will now implement the Aurdino so I can control the filters thru SW.
Brgds
Brgds
Are you saying you need a pullup on the output of the RST chip (TSP3809)? It is supposed to be totem pole output, not open collector.
I don't see J2 on the schematic.
J2 is on the smaller boards. As I wrote in the buildthread - I missed the TSP3809 :-(
Have ordered it now but I got audio pulling RST up.
Brgds
Brgds
Just one point about the shorts, In 31 years of working for major electronics companies I've seen plenty of them. Just this past month an associate got a lot of prototype boards in that had shorts. These were from a reputable board house. Prototypes normally don't go through the same board level checks that production boards go through.
In the 80s when I worked for Texas Instruments, we used to use a 5V 20A supply to find shorts. It would usually clear them with no problems. This was in multilayer boards where the shorts were sometimes internal.
I always inspect boards with a 7X loupe or stereo microscope before assembling anything.
I wonder what version of the Aurdino environment this is tested on? Aurdino 1.0 just creates a long log file of errors trying to verify/compile...
Yes, I imported the lib LCDi2cW. Yes, I added the missing "/*" on line 1.
Anyone who succeeded?
Brgds
Brgds
I have uploaded on to the net. You can download it from here
LCDi2cW.zip - 4shared.com - online file sharing and storage - download
Heartwinter, what version of the Aurdino environment did you use to succesfully compile the code?
Last errors:
In file included from Soundciti_dac.cpp:45:
D:\projects\arduino-1.0\libraries\LiquidCrystal/LCDi2cW.h:24: error: conflicting return type specified for 'virtual void LCDi2cW::write(uint8_t)'
D:\projects\arduino-1.0\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
Soundciti_dac.cpp: In function 'void loop()':
Soundciti_dac:647: error: 'writereg' was not declared in this scope
This is too deep for me but of course has an obvious solution ;-)
Brgds
OK, the very usefull 30min rule kicked in...
A new post then.
As soon as I get this working I'll post the .ino file so you don't have to invent the wheel again.
Brgds
A new post then.
Brgds
You can interface the dac with arduino through 2-wire serial control mode. I will provide you with all details including connection diagram and code. You will also need to buy a I2C level shifter board for interfacing the dac with arduino.
Yes please. Aurdino 1.0 IDE doesn't work...
Brgds
Still no input from our dear vendor on how to get the provided code to work with Aurdino 1.0...
Sorry heartwinter for the strong words and frustration I went thru during the build. The PCB's are quite bad don't you think? But anyway when sorted out there is functional code for Arduino 1.0 and parallel LCD in the build thread which I glued together from glt's work on hifiduino.wordpress.com. Since I don't posses a serial one someone else have to fill in the right code for it - preferably with a choice at the beginning chosing which connection to use.
For my part I will cannabilize one of my audio-widget dacs to use it instead of the 2707 as usb input. I feel quite sad about this since it sounds very, very good. See if I can find the least damageble way of doing it.
I have also signed up for Ians stuff which I plan to use as the interface for my new shigaclone as a starter. Ideas of diy SACD/DVDA players are most welcome.
There seems still be issues but we will sort them all out and I hope you will be with us in the process.
Brgds
Brgds
- Group Buys
- High Performance WM8741 Upsampling DAC New Version - Group buy
