high-low converter, resistor divider?
In my old car I had to use a high-low converter to power my sub amp from my rear speakers. My sister wants to do that with her car right now until she replaces her deck. The ones I bought were isolation transformers. Can she just use a resistor divider (basically a 10k pot) to do the same thing? I was thinking that there shouldn't be much of a problem with it, it's significantly larger impedance than the 4-ohm speaker...
Line Level Converters (LLC) are available pretty cheap. The problem with a resistor divider is that the speaker outputs aren't ground referenced like RCA line inputs are.
In theory it should be possible to run just one side of a speaker output directly to a 10K ohm amplifier RCA input, using the car ground as the other side. You'll only get 4-5 volts rms, which most amps can handle fine. The only issue is how much noise you pick up in the ground side.
