Tube preamplifiers have often a typically 600 ohms output impedance. How long (max.) should I keep the cables (in balanced mode) to the active speakers, which are distanced 3.5 metres (11.5ft) from each other?
Thanks,
-dan
Thanks,
-dan
With an output impedance as low as that you should be able to drive quite long cables assuming that the output stage has a high enough standing current to drive a capacitive load. I suggest you read SY's "a heretical line stage" and/or from page 572 onwards in "Valve amplifiers" by Morgan Jones if you have not already done so.
Thanks,
-dan
An easy, rule of thumb is to calculate the frequency where Zout = cable (and amp input) capacitance, because that's the -3dB freq of the low pass filter formed by Zout and cable cap. Alternatively, if you have a 'target' -3dB, say 30kHz, you can calculate the max cable cap you can afford. Then when knowing the cable cap per foot you know the max length you can afford.
Example: you want the -3dB at 30kHz. Zout = 600 ohms.
The impedance of the capacitance Zcap = 1/(2*pi*f*C); Zout = 600 ohms so:
600=1/(2*pi*35*10^3*C) so you rework that and you get C = 1/(600*2*pi*35*10^3) and that comes out to about 750pF. With a reasonable cable of 150pF/feet you can afford about 5 feet.
jd
I hope you meant pF/m there jann - I'm sure you could find cable C that high but I would put the typical range at ~ 1/3 that # for twisted pair and < 15 pF/ft "low capacitance" cabling is available
also single pole roll off is slow, to keep 1 dB 20KHz flatness you would want >40 KHz fc, 0.1 dB requires over 120 KHz
Thanks a lot guys, didn't expect that much help in such short time. A knowledge of mine (not a friend, my friends don't have that money) is thinking to buy an Audio Research REF5 preamp, which is 600 ohms. The active speakers are ATC SCM150 SL AT (active), but they have 10k ohms input impedance. AR says that it should have min. 20k input impedance and 2000pF capacity. The cable is one I made myself, Furutech SA22 in 3 metres length per side. The guy is thinking to switch to Kimber twisted, because of its low capacitance. I'm worried this might not work...
2000pF capacitive load sounds a bit high for this preamp.
jd
Agreed. I was just using some numbers to illustrate the process.
I also think that with a balanced 600 ohms Zout the value to use is probably 1200 ohms, no? Meaning even less capacitance should be allowed.
jd
It say that the maximum capacity shouldn't exceed 2000pF, but preferable less:
Audio Research REFERENCE 5 Vacuum Tube Line-Stage Preamplifier
Jann, where Germany, Belgium and The Netherlands meet, sounds like Vaals, no? I'm from Eupen, and spend some youth in a disco called I think Spuugh or something like that.
Was a lot of fun...
Was a lot of fun...
Was a lot of fun...
Heerlen. 15 miles from Vaals.
The only disco I know from way back is the Queens Club in Vroenhoven, your country. Only one that stayed open till 04:00 AM.
jd
Hmmm.... Why I usually assume 100 pF per meter? The time to go to the library to refresh memory... 😉
Anatoliy,
Isn't it time to upgrade the avatar 😉 ?
Are you sure Johannes it is so simple? 😉
I think a lot of studio cables are around 100pF/m
I have some Belden cables and specs handy.
Belden 1800F is the low-C winner so far at about 12pF/foot conductor-to-conductor.
By contrast Belden 1192A in star quad is about 57pF/foot
A nice RCA cable I have measures about 15pF/foot
radioshack 16Ga speaker zip lead measures about 15pF/foot also
Monster "Prolink" XLR studio cable: 18pF/foot
Monster "Prolink Performer 500" XLR studio cable: 35 pF/foot (the fat mic cables that rool themselves up after the gig)
- Tubes / Valves
- High impedance balanced output: how long the cable?
