Tesla Coils and Plasma Loudspeakers are characterized by an extremely high frequency electrical resonance. This resonance is modulated to produce energy in the audio bandwidth.
I am curious as to what frequency ranges are non-hazardous and/or not regulated by the government.
As far as I understand, the government along with private parties use certain frequency bands for military / communication purposes (ex. RF). Reproduction of a device that emits significant electromagnetic radiation may interfere with these operations. In addition, the resonance of the transducer could couple to these signals and produce undesirable levels of noise.
Also, high frequency electromagnetic signals contain a lot of energy. I believe radiation is emitted. These signals can be hazardous to humans if they contain sufficient energy (ex. Microwaves).
What frequency ranges would not have the aforementioned effects? Could anybody offer further insight on this?
Thanks,
Thadman
Thanks,
Thadman
Maybe overreacting, but, I don't think Mr. Tesla died young.Also, high frequency electromagnetic signals contain a lot of energy. I believe radiation is emitted. These signals can be hazardous to humans if they contain sufficient energy (ex. Microwaves).
Anything in the kilohertz is not going to bother you unless you find a way to drive more than a milliamp or 2 right through you, by direct conduction or standing around an antenna with either lots of directivity or maybe kilowatts in. Oddly, I've taken direct hits from the collectors of TV flyback circuits (what is that 15kHz?) at maybe 1000 volts or so and did not get shocked, just burned at the point of contact. (Didn't affect me none. {tic, tic}) The resonance isn't a real big factor in safety, except that it's easy to make big voltage that way.
FCC Part 15 is a good place to start. No serious commercial product should seriously/deliberately violate it. Hams can and do get involved on both sides of this issue.
ARRLWeb: FCC Part-15 Rules: Unlicensed RF Devices
In other words, if no one can detect it outside your yard, it's kinda legal to boot.
Interesting point. I failed to consider that.
A tesla coil utilizing vacuum tubes could oscillate at an incredibly high frequency. I believe Krytron tubes can theoretically switch in nanoseconds. Are ultra high frequencies hazardous to human health? How would one establish an upper frequency limit for radiation?
Thanks,
Thadman
Scott has it correctly. FCC is the authority here, in the USA. Its rules and regulations (what's the difference between a rule and a regulation?) specify what levels are permissible.
Yes, hams are supposed to be in compliance, and in fact most of them are. Part 15 is for the general public and part 97 for ham radio specifically.
Both documents are available on line, probably from fcc.gov in the appropriate section.
There is much mass hysteria on this topic. Most of it is worthless.
I really never thought much about Tesla coils, but I think some are still made with spark gaps as switches, which probably have breakover speeds at ionization that rival any semiconductor or valve. But the oscillation frequency is still determined by the LC circuit. It's only the harmonics that reach into gamma rays (well, not really)
Yes there are national, maybe even international spec limits for any known kind of radiation. I figure you're worried more about health issues than EMI/RFI compliance. I can't tell you the name of them or where to even look. You're good to worry about the frequency. X-rays spook me. Anodes over 30kV give me the heeebeeegeeebees.
Virtually all frequencies are regulated by governments worldwide, from ULF submarine communications up to the infrared. Emissions below some levels are insignificant dependent on frequency. Depending on your definition of insignificant...
Beyond that there is the unregulated ultraviolet (although sunbeds are regulated) then regulation takes over again with x-rays, and gamma rays. So the entire electromagnetic spectrum apart from a small band round about the visible light frequencies are regulated.
There is a great deal known about this subject, and a good deal unknown.
The radiation to which you refer and which is damaging is more properly called 'ionizing radiation', which is a subset of frequencies. None of the frequencies involved in radio transmission are ionizing radiation, it's all higher frequency than light. Radio can heat things up though, as in microwaves.
There is also particle radiation. This is the emission of high-speed sub-atomic particles from radioactive substances. Again, this can be hazardous, but it has nothing to do with radio (despite the name radioactive), or any kind electromagnetic wave in the conventional sense.
The average solar (electromagnetic wave) irradiation at the earth's surface (all frequencies) is about 200 watts/square metre, but this is only a ballpark figure, the figure is low at the poles and varies seasonally.
This is not the so-called 'cosmic radiation', which is again particular, although some of these do originate in the sun.
The FCC is the US body responsible for regulation of the radio spectrum, and I guess the AEC for ionising radiations.
Stray emissions from electronics are regulated in Europe on the basis of EMC, or electromagnetic compatibility.
Segments of the band are quiet as the grave by comparison, some are filled with the echoes of tropical thunderstorms.
It's a very difficult subject because it raises a lot of strong feelings around the health issues, partly because these can only really be decided by critical examination of historical data which is currently not exactly plentiful or of unimpeachable provenance and you can't get the data unless you expose some people to some risk and a balance has to be struck involving commercial interests that impinge on us all that at the same time stops somwhere short of unleashing a second Dr. Mengele.
w
w
I've considered powering a Tesla Coil by a two-cavity klystron oscillator, which is capable of producing an UHF resonance.
This is why I'm worried about the health issues associated with electromagnetic radiation. I'm not sure how high I can go before dangerous radiation levels are produced. I know the "health" issue is ambiguous, however are there any rules of thumb I could use to determine an upper resonant frequency limit?
I think you need some SRF quality to the secondary if I'm not mistaken. By the time you have enough turns ratio it'll probably be too low for any UHF drive aspirations.
Instead of using an Air-Core transformer, wouldn't it be possible to allow a Marx generator utilizing vacuum tube capacitors and spark gaps (or triggered gaps using cold cathode gas filled tubes) to pulse a two-cavity klystron oscillator which creates the voltage potential necessary to generate the arcs of lightning traditionally associated with Tesla Coils?
Is it even possible for a civilian to purchase two-cavity Klystron oscillators and cold cathode gas tubes, specifically Krytrons?
I'm thinking some of these components might be available through Russian military surplus distributors. However, Krytrons are often used as the triggering mechanism for thermonuclear weapons and I expect they may be tightly regulated.
Scott has the right link. Legally, you must abide by Part 15 and in particular, the willful interference parts. You can still be in compliance with Part 15, but if your intent is to willfully jam or interfere with other legal operations, you are in violation. Nothing happens until someone complains or possibly finds out what you are doing.
Scott is also correct that Amateur Radio operators routinely get involved with these types cases and they do a pretty good job getting the ball rolling. From there they partner with the FCC and other authorities to drive all the nails into the coffin.
You consider 87 young?
Yes, in fact the hams were responsible for bringing the spurious radiation for the first broadband over power line test into question.
The US army knows a thing or two about RF radiation and the effects on the human body.
Protection of DoD Personnel from Exposure to
Radiofrequency Radiation and Military Exempt Lasers
http://cryptome.org/dodi6055-11.htm
More food for thought.
ELECTROMAGNETIC RADIATION HAZARDS (U)(HAZARDS TO PERSONNEL, FUEL AND OTHER FLAMMABLE MATERIAL)
NAVSEA OP 3565/NAVAIR 16-1-529 VOLUME 1
http://www.cpp.usmc.mil/mcas/docs/NAVSEA OP 3565 Vol. 1.pdf
Don't worry about Volume 2, it is in regards to thing that go boom in a big way.
- General Interest
- Everything Else
- High frequency electromagnetic energy. hazardous? legal?
