It could just be from somewhere else, but the symbols and schematic style are pretty much what they use - I've never seen it anywhere else. To be honest, though, I never rated them for their valve based designs. They have often chosen less than ideal operating points for valves in small signal stages in my opinion.Wow, I'm amazed that Elektor would publish a circuit with that many faults.
Good Line-Stage with PCC88
Hi all!
What good pre-amp or line-stage recommend with pcc88 or ecc88?😕🙁
thanks
Hi all!
thanks
Now let me think - I'm sure I've heard that question before somewhere. Could someone assist my memory?
SRPPHi all!
thanks
It is these questions, but the answer was not to be!?😡🙄
I dunno about hi-end (and a definition of that is very unclear anyway) but this thread is hi-troll for sure 😀
If it's the one from post 210, those aren't Elektor symbols. By the mish-mash of symbols it appears to have been created by cutting and pasting various circuit blocks from different sources.
Acrobat Reader tells me that was drawn using CorelDraw in the evening of 2 July 2012. It appears to be identical to the one provided by 'formula 22' (the OP) in the first post of this thread. He and Gost22 seem to find their circuits from the same places, and make similar claims about them.
I note that formula 22 seemed to stop posting on DIYaudio in late August 2012. Gost22 started in September 2012.
No - I was refering to the one in post 227. Sorry if I was not clear.If it's the one from post 210, those aren't Elektor symbols. By the mish-mash of symbols it appears to have been created by cutting and pasting various circuit blocks from different sources.
Acrobat tells the same story as for the one in post 210, however - ex Corel Draw, so it's anybody's guess. Certainly it could still be a cut and past job, but the resistors, valves and labelling are very much in the Elektor style.
Joined 2009
wow, what a strange thread. Why does the poster have to post something exotic to be of interest ? and who cares if the 26 pre-amp thread is over-rated, it's like the crowd always follows...
I don't see why you can't make a really nice pre-amp with the ECC88 and base it on well known proven topologies. The devil is in the details and the resulting sound can change a lot depending on the choice of operating points, quality of power supply, layout etc. I'd be interested to learn more about these things - how to design a really good pre, basic stuff and all that.
Hi All!
Anyway now I'm working on the pre-amp offered Tony.
I'm interested to hear the sound it gives.
If anyone has any suggestions about improving of the preamplifiers let you go.
thanks and cheers!
thanks and cheers!
Hi All!
thanks and cheers!![]()
is there any kit available of this pre-amp?
If you are looking for a PCB, Tony made it without a PCB, just air-wired. Or are you looking for the components and the box?
Wondering which pre-amp?😕
thank you!
Definitely. But an older version.I am going back to my theory that this is a Turing test, running v22.0 of the software.
Hi 12E1!
Give the schematic of the old version and try that option.
thank you!
Hi 12E1!
thank you!
Let me google that for you
- Tubes / Valves
- High-End Tube preamp with ECC88
