High-End Regulated Buffered Inverted GC
Pedja said:
It probably does but only marginally, since in this case this impedance is hugely defined by the feedback. Note that here this lower impedance might not be necessarily positive thing.
I'm not going to test two pairs of regs, at least soon, if someone wants to compare single or double pair, it would be nice to know.
t. said:
Well I just had to try taking the regulator circuit out of my amp, I replaced the smaller caps on the LM3875 pins with 1000uf and let it run in for a couple of hours.
So now I have normal GC but with buffer,
first impressions are :bawling: everything sounds thin, the bass now sounds loose but worst of all those beautiful mids are gone.
The amp is back to normal and is making music again, sorry I just had to make sure
Thanks for all that work, Leon.😎
Well you know how it is😉 I had to try it,
I'm going to take the bits to work tomorrow and build your buffer stage in my lunch break, just intersted to see how it differs to Pedja's
BTW I had a few probs with my regs to start with, nothing popped but the voltage on the output pin (both rails)
only dropped by 1 volt no matter what value resistor I used on the adjust pin.
In the end I fitted my spare pair of regs and they worked fine😕
Better go to bed now, its getting late, work in a few hours
That is interesting. Here's my friend's impression when comparing AC powered, minimized GC (Brian's premium kit with Panasonic caps) to Carlos' circuit (both in a same chassis):
The sound of the new amp is washed out, bass lacking definition, not enough liveliness and sparkle, reduced soundstage (rather flat).
There was no preamp used at all, signal from CDP fed directly to the pots mounted on RCA inputs.
While listening today in my house, I noticed that the sound improved since I tried it last time and mids were indeed somewhat softer and maybe even more pleasing than my Patek, but bass was definitely worse and resolution was lacking.
Nevertheless, this amp is not bad at all, and I've built GCs that sounded much worse. Good work Carlos, with additional tweaks you might even get there😉
carlosfm said:
Nuuk, let's see if we find out what's happening with your regs...
You have 8 diodes (2 bridges) and 2 pairs of regs, right?
That is, the two pairs of regs share the same diodes, right?
Now look at the schematic.
You join the output of one reg with the ground of the other one to make the ground, right?
What happens if on the other board you pick the other two lines to do this?:hot:
:xeye:
Nick, it seems important thing was left unsaid explicitly and since you have explained your setup (I think you did, but it is not easy to go back through the thread to check it), I do not know how that passed by… Anyway, with such supply the whole set up before the regulators (windings/rectifier) must be floating. In fact, positive regulators yet can be driven from the same source, but negative can not. Generally: one winding and one rectifier for each regulator.
:xeye:
This listening experience is at total odds to what I hear when using a regulated PSU. I don't understand it. Leo has just reconfirmed to himself of the differences as I did a few weeks ago. I have sat with Leo before and trust his opinion, his findings are the same as mine and of others who found the same when using a regulated PSU. I hope to get together with Leo and some other 'ears' I trust in the near future to compare further. BTW my reg GC is NI and not buffered yet the superiority of a regulated supply is still obvious. And please can we keep the snide remarks to ourselves.
I'll just go over my set up again to avoid any confusion.
I am using one 25 VAC 300 VA transformer which feeds two rectifier bridges (MUR860's). This unit supplies two rails of 36 volts and is connected to both the regulator modules in my amp as shown in the circuit diagram.
The only differences to that circuit are that I have 0.47 uF caps from the input pins of the regulators to ground as shown by C5 and C6 and I have used the extra protection diodes.
If I break the connection marked X, both positive and negative voltages are correct, ie +/- 26 volts but if I connect the output of the negative side to the ground of the positive side (point X) I get positive voltage on the output of the negative regulator! 😕
I repeat, this is on one module only the other module works fine. Input voltages on both modules are correct (36 volts)
