A bit bigger and louder than you asked for:
Audax PR 17 HR 70 2CA7 17cm 6.50" Professional Grade woofer, PR 17 HR 70
Great minds think alike I guess. ;-)
suprafox
http://www.supravox.fr/anglais/haut_parleurs/135_LB.htm
fostex fe125en
http://www.fostexinternational.com/docs/speaker_components/pdf/FE126En.pdf
beyma 5g40
http://profesional.beyma.com/pdf/5G40 NdE.pdf
fostex fe125en
beyma 5g40
Scanspeak. Watch out 92,5dB 2,83V that is 2W because the impedance is 4 ohm. so spl is 89,5dB at 1 W.
davis 13mp5gr
doesnt look like 92db only 660-1600Hz
95 or 96 dB, that's one hot 5"!B&C 5MDN38
I thought the Galaxy Audio S5N-16 was hot for a 5", but it's only 91 dB one watt one meter.
hi guis, j'm desperate because don't find a decent 5" midrange. i need minimum 93-95 db. f3 is not important because the speaker is four way. if you know one, please, tell me the model. thery thanks in advanced. bay
-smaller than a 5" driver, but lower mms as a result. (..it also needs only one narrow-band notch at around 5.1 kHz.)
The Madisound Speaker Store
- high efficency 5" midrange
