Hifonics XXV-Cyclops repair
Ok... def not have 15v on either L7815 or L7915. I followed pin 14 of the output card to 3rd leg of the L7815.
L7815 has 8.71v on pin 1, 0.002v on pin 2, 7.14v on pin 3 right now
diode check red lead on pin 1 - pins 1-2: OL, Pins 1-3: OL, Pins 2-3: .510
diode check black lead pin 1 - pins 1-2: .551, pins 1-3: .559, Pins 2-3: .920
Defective?
L7915 has 0.001v on pin 1, -9.10v on pin 2, 8.35v on pin 3
diode check red lead on pin 1 - pins 1-2: OL, pins 1-3: .986, pins 2-3: .532
diode check black on pin 1 - pins 1-2: .555, pins 1-3: .522, pins 2-3: OL
Also defective?
Could my supply be the prob? As soon as I connect remote my suppy is going from 12.56 to 8.5v at the power terminals... using the limiter... :confused:
Some pics as requested. lmk if you'd like any others in better quality pic of a certain area.
I have +5.17v on C53 + leg, and 0.000v on neg leg & 0.000v on pos leg of the C54 and -5.41v on the neg leg.
Attached is the 4 leg photos and one of my settings.
No, there doesn't appear to be any swing... if I put the black prob on ground terminal and test any of the transformers I get 12.66 volts on every primary winding (no matter if I touch the pos or ground, theres power on all 3 primary) with the amp off, and drops to 8.2v as soon as I add the remote (through resistor).
The transformer feeding the 15v I get 0.000v if I use ground terminal, and 12.66v (or 8.2v) if I connect black prob to one of the primary windings. If I test black lead on the secondary center and red on the 15v I get 0.000v
These are the 4 windings for the 2 transformers closest the driver card. They have the small windings for the 15v and I think 12v or some other lines (the other transformer).
The first two are from the 15v one.
